Old 07-20-2006, 05:21 PM   #1
97guns
very surprised when i found out my '71 has rear coil springs !!!!
ive really never seen rear coils on a vehicle from this era much less a truck. every late 60-early 70 car ive had/seen has always had rear leafs. is there an advantage in having rear coils over leafs?
97guns is offline   Reply With Quote
Old 07-20-2006, 05:30 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: very surprised when i found out my '71 has rear coil springs !!!!
Coil springs were standard in the 67-72 Chevs. Actually, from 60-72 I beleive.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-20-2006, 05:42 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, it's a loop hole GM used to have that long trailing arm in stock car racing, it had to be used in a production vehicle, so they stuffed it under the truck. This way they could run it in races.
It's a very good set up, good ride, hooks up good, easy to adjust.
Sucks running exhaust though.
Old 07-21-2006, 12:57 AM   #4
409biscayne
409biscayne's Avatar
It's really not a bad system , at least in the 1/2 tons anyway . And it does hook well at the strip . Isn't Nascar still using trailing arm ?
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 07-21-2006, 09:10 AM   #5
lilred67
lilred67's Avatar
yes,nascar is still running it!
lilred67 is offline   Reply With Quote
Old 07-21-2006, 09:43 AM   #6
Joe67
67 is sold
Nice - I never knew about the Nascar connection to the rear suspension setup on our trucks
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-21-2006, 09:43 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Coil spring
Adv: Rides nice
Dis adv: Unless helper springs are used, can't haul a real heavy load.
Leaf Spring
Adv: can haul heavier loads
Dis adv: Ride is not as nice. More stiff and harsh.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-21-2006, 09:45 AM   #8
jacobs
jacobs's Avatar
I installed 3/4 ton Custom Camper coil springs on a 70 1/2 ton and it got rid of the mushy soft ride and greatly increased the payload. At the same time I replaced the shocks with Custom Camper. These shocks are valved 50 50.
jacobs is offline   Reply With Quote
Old 07-21-2006, 02:46 PM   #9
Longhorn Man
the coils and the leafs are rated for the exact same load.
Old 07-21-2006, 02:55 PM   #10
Sweet72
Sweet72's Avatar
I was told by a local bracket racer that you want the light 1/2 ton coils to get the tires to hook up, as opposed to the heavy-duty rear coils like my GMC has. I wasn't very impressed with my trucks handling when loaded heavily, real bouncy and light on the front tires.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-21-2006, 03:01 PM   #11
67ChevyRedneck
Then why did my truck squat so bad that the tires almost rubbed the fenders when I had it loaded with wood and my dads 69 with leafs didn't squat half as much as mine with a bigger load? The 67 was probably overloaded, but the other truck would have been as well???
Learn something new everyday
Jesse James
Project "On a Dime"
Old 07-21-2006, 03:37 PM   #12
motocrosschump
you guys always bursting bubbles
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 07-21-2006, 03:58 PM   #13
Longhorn Man
My statement was kinda misleading, and somewhat of a loaded comment.
They are in fact both rated the same.
So up to the load limits, they are both 100% capable.
For mild overloading, the leaf will take a little more abuse, still act as a spring and an active suspention.
For extreem overloading, you will ruin the leafs.
Coils will just go into coil bind... one coil stackes on top of the other.
