Old 07-21-2006, 09:01 PM   #1
fearnatine13
Boondock Saint
Re: 1969 chevy to 1965 gmc swap
You're absolutely right, it is just a v-6 not an inline. but the fact it needs to be rebuilt, and i have a brand new just broken in 350 in my current truck makes me just want to do the swap.
And shepards we shall be
For Thee my Lord for Thee
Power hath descended forth from Thy hand
That our feet may swiftly carry out Thy command
So we shall flow a river forth to Thee
And teeming with souls shall it ever be
En nomine Patris, et Filii, et Spiritus Sancti
fearnatine13 is offline   Reply With Quote
Old 07-22-2006, 04:29 AM   #2
Bob B.
That would make the swap more complicated. The motor mount towers are completely different that the V-8 or straight 6 towers. The V-6 with a manual transmission has rear mounts on the bell housing. You will need to remove the crossmember under the bell housing and add a crossmember farther back with a transmission mount. But, you shouldn't have any clearance issues. That V-6 is a lot larger (and heavier!) that a small block Chevy. It can be done if you have all the parts. Those V-6's are really quite some engine. Hate to see one replaced with a 350!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
