07-21-2006, 03:09 PM | #1 |
Underbed tank/fuel cell and Elec in tank pump
I've got TPI and am contemplating to move the tank out under the bed. I'll want a tank that utilizes an intank fuel pump and have an acurate sending unit.
What would be a good source for this? I was also thinking of just spending the dough and getting a custom fuel cell built for this application and with baffles.
'67 C10 Short Stepside 5.0TPI/700R4 |
07-21-2006, 09:59 PM | #2 |
Re: Underbed tank/fuel cell and Elec in tank pump
Fuel cell guy is th one to talk to for an aluminum tank.
ECE carries a stainless tank (big$$$$) Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-21-2006, 11:00 PM | #3 |
Just curious, are you running an inline pump now with the original in cab tank? How did you plumb your return line if you don't mind me asking?
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
07-21-2006, 11:10 PM | #4 |
It's rigged, ugly and I get fumes in the cab. I bought it like this. It's got an in-tank pump. I'm not sure if the pickup goes deep enough. It sometimes starves for fuel if I hang a turn too fast. It looks like they just drilled a hole in the top of the pickup piece and ran a line for the return.
07-21-2006, 11:14 PM | #5 |
I had considered taking 2 in cab tanks and making one. If you use a 71-72 sender, and attach an in tank pump to it at the bottom, you could also build a baffle to sit inside the tank. The 71-72 sender has a return fitting on it already. A guy on ebay sells in tank pump kits. My thought is that I can keep my spare tire carrier in the back and leave the truck looking stock that way. Probably be easier to put one out back, but it may cost more.
07-21-2006, 11:24 PM | #6 | ||
