Its always something!
Any a/c guys?
I have a 97 vortec 350 in my 72. I used every thing for the a/c from the 97 except the condensor. I have put 32 oz of 134a & it still doesnt cool. I hooked up the pressure switch on the accumilator. There is a switch on the high pressure side of the manifold that goes on the compressor & a switch on the back of the compressor. Do these need to be hooked up for it to work properly?
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() ![]() Member of the patina club |
Saving one 72 at a time!!
![]() Join Date: Sep 2005
Re: Any a/c guys?
Shane,
Does the system call for 32oz in the 92? Is the compressor running (Clutch engaging)? If it is, what are the pressures your getting on your low side gauge. Since you changed the condenser - the high side would be good to know as well. If the compressor is comming on then I would say that those switches may be for something else, the key thing is the compressor coming on and the refrigerant flowing. When you moved it over did you disassemble the lines from the compressor and reciever (accumulator) tank? the reason I am asking is to see if the cap tube is still there and if the screen was clean. Let me know Shane and I bet we can get you going. Tony PS- I'm in houston and I know damn well that AC is as important as the motor itself! - Ive seen on the news that you guys are getting it good as well up there. |
Re: Any a/c guys?
I agree with cypress's troubleshooting. clutch engagement, and pressure in the lines are the first 2 I'd check. Then if those are going, I'd look for leaks. 32 oz is a lot of coolant.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
Re: Any a/c guys?
Tony
The 97 system calls for 32 0z I have put 3 12 oz cans of 134a in. The clutch is engaging. I am unsure of the pressures my guages are shot they were pegging out the low side & showing 250-300 psi on the high side. I had to dissassemble the system because I had to get the hoses modified but every thing has been covered up. The condensor is the origional for the 72 so I couldnt use the orfice tube. Shane
Re: Any a/c guys?
Shane,
If the low side is shooting up past 50 psi and the compressor is engaging - then either the compressor is not pumping or the refrigerant is not flowing. Think of it this way - the high side of the compressor is freon leaving and on the low side its comming back from the evaporator - so if the pressures are equaling out - then it is not being condensed. When you say you cannot use the orfice tube-does that mean the old one out of the 72 or the new one- because it has to have one to work and it has to be the correct metering for that set up. (or close, it doesnt have to be exact-but it has to have one close) Gauges are going to be a big help for you to try and pin point the problem but If you have a metering devise such as a orfice tube or cap tube in place then the first thing I would try is to dump some of that 134 and see if the pressures go down - while running the truck. Also, we need to see if the condenser is getting hot, and/or is the suction line (the big line) comming from the accumulator is getting cold. If the suction line is not getting cold - then I would lead to say that 1.you have either lost your orfice tube or blown it out 2.you have a restriction line the system somewhere or 3.that there is no orfice tube and the system is just pumping around without metering. Listen I know it sucks, but if you want to try and fix this yourself I would say that guages are going to be a must- do you have a buddy that may loan a set to you? Cause I am sure after all that the last thing you want to do is have to buy a set of freaken guages. Man, if you where here, i'd come over and help you.- my wife and kids are away T |
Re: Any a/c guys?
Also, I forgot to put in the last post.
The pressures that you are looking for are at start up you should have around 200-230 high side and 40-60 on the low side. then as the truck starts to warm up you will see the high side go up and the low side go down. When the truck is cooling inside and the doors are shut - you'll get down to about 30psi on the lowside and then the compressor should cycle. At that point your head pressure will be at 250,260, or even 270 depending on how hot it is outside and your fan clutch. I am pretty sure that that compressor cycles at 30psi it may be as low as 25 or so - but by that point it will be blowing cooooooooold anyway. T |
Re: Any a/c guys?
Hey Shane, I leaving for the night so I'll check on you tomorrow -
When the cats away the mice will play - hehehehe! Going to check out the bars and see if I can find me some women trouble. Good luck Shane. |
Re: Any a/c guys?
I was told that the orfice for the 97 is located in the condensor. Where would it be located in the 72 system? Is there any other location where I can put the orfice? The small line is getting hot but the big line is not getting cold. Its slightly cool but not cold. I have a b-day party to go to tomorrow so I will not get to mess with it until the evening.
Thanks for your help Shane
#9 | |
Re: Any a/c guys?
Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside ![]() 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! Last edited by ronh72c10; 07-22-2006 at 08:40 AM. |
Re: Any a/c guys?
The orfice tube is normally in the high side line going into the evaporator - or the accumulator - where the line screws on- inside the pipe itself you should see it in there.
T |
Re: Any a/c guys?
The orfice tube would never be in the condenser, maybe your thinking the drier?
Re: Any a/c guys?
If it has an orifice tube its normally inthe evaporator inlet Im not sure but I think the older chevys used a valve like a throttling valve similiar to an expansion valve. your low side pressures should run no lower than 20 lbs.thats usually wheen the low pressure cut off switch engages.
72LONGHORN 350 CI TURBO 400 A/C P/S P/B HEAVY DUTY SPRINGS ALL THE BELLS AND WHISTLES. TUCSON,AZ. 2005 4X4 DODGE RAM 1500 "HEMI"LARAMIE 1961 OLDS DYNAMIC 88 394 4BBL UNDER CONST. |
