Old 10-14-2002, 04:56 PM   #1
greasemonkey
greasemonkey's Avatar
Unhappy Help! Brake lights won't come on!
I discovered that my brake lights are not working, so I replaced the fuse, checked the wiring, and cannot find out what is up with them. My truck's floor was sandblasted the other day, and the sand got everywhere, could that cause a problem? Up until then they worked fine. Please help, I have to drive it to college tomorrow!
John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 10-14-2002, 07:28 PM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Find the switch that gets actuated by the brake pedal. Pull off the plug and short across it (the plug, not the switch). If the lights come on, your switch must have sand in it. Take it off and shake it around. When the plunger is out, it should be on. If you can't get it to work, I think you can get a new one at just about any auto parts store.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-14-2002, 07:32 PM   #3
Gordo
Smile
Check your brake light switch that's attached under the dash, above the brake pedal. It's possible it's unplugged or broken, also check for power at the orange wire, if you have power there then apply brakes and see if you have power at the other wire. This switch is live with or without the key on. If you have no power at the orange wire go to fuse box and check for power at both sides of the fuse, this also should be live all the time. If you have power everywhere, check the 1157 bulbs in the rear, these bulbs should light up with the signals/hazard switch also. If everthing still checks okay, the problem may be in your signal light switch, the brake light circut passes through the signal switch.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 10-14-2002, 09:00 PM   #4
greasemonkey
That was it all right. I took the switch off, tried to depress the plunger...and it stayed down. There was sand in it too. So I bought a new one for $3 and it works fine now. Thanks everybody.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
