Yet, another 6 Lug Rotor ??
OK, this most likely has been asked before. What Chevy/GMC trucks from 73 thru 87 came with 6 lug front rotors that are 2wd? I'm getting ready to do a drum to disk swap and already have all the other parts for this job, and need to know this. Should I be looking for the 2500 series or is there a 6 lug 1500 series? I've also heard on here about a 1990 3/4T 2X4 Light Duty rotors work. There is no listing that I can find for a 1990 Light Duty truck. What series was that? I have read on here about the thickness of the late model rotors being different also.
All the part books never say if they are 6 or 5 lug, and these parts store clerks don't seem to have a clue when I call, (Advance, Autozone)..... thank, steve
1997 GMC Sierra Ext 1965 Mustang |
its all about the +6 inches
Re: Yet, another 6 Lug Rotor ??
no 73 - 87 trucks were 2 wheel drive and had 6 lugs. All there 2 wheelers were 5 or 8.
Running on empty
This might help.....I found it in the FAQ section...
http://67-72chevytrucks.com/vboard/s...d.php?t=120195
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
#4 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
I went round and round through that, nothing interchanges. It's convert to 5 lug or bite the bullet and buy the aftermarket roters. The roters were cheaper than buying 5 lug rear axels for my dana 44 posi...
If you can't drive it park it! If you can't park it milk it! |
if u could find a stock 10 Bolt front end on a 1/2 ton chevy 4x4 they have 6 lug rotors on them
Stout Racing a Division of Disciples Performance ![]() |
thanks.....that helps........
what happened to flint mi
stout, will those rotors bolt up to 71 72 spindles ??
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile |
i believe so but just for good measure find a set of 73-87 chevy spindles at the junker and take them just incase doesnt hurt couple bucks
