Old 07-24-2006, 09:51 PM   #1
l79m20
Correct part numbers
Hey group was driving my 14 year olds 72 1/2 ton (chevrolet) when the passenger side exhaust manifold broke in half with the lower side still connected to the exhaust pipe, what a terrible racket. Just blew apart. Well anyway need to get a used one and was wondering if anyone of you knows what the correct GM part number is for the passenger side exhaust manifold. Any Ideas? Thanks for any help .................Joe
l79m20 is offline   Reply With Quote
Old 07-25-2006, 04:19 PM   #2
l79m20
Re: Correct part numbers
Just maybe I would have gotten a reply if I gave all the information. Sorry about that.....The numbers I'm looking for (Passenger side exhaust manifold) are to a 350 cu/4 barrel, auto with air. hope this brings some replys.......Joe
Old 07-25-2006, 05:02 PM   #3
Americanrider
Is that the straight dump ramhorn or the type that curves back?
Americanrider is offline   Reply With Quote
Old 07-25-2006, 06:12 PM   #4
l79m20
Americanrider thanks for the reply . The manifold looks to be ramhorn style and the brace for the compressor bolts to the manifold near the bottom not from the top......................Joe
Old 07-25-2006, 07:18 PM   #5
Sweet72
Sweet72's Avatar
Here are some repro. rams horn manifolds on ebay. I don't believe GM makes them anymore. 2WD pickups use a angled dump where it hooks up to the stock "Y" pipe. These have the air injection holes for smog stuff. Occasionally you will find good originals on ebay.
http://cgi.ebay.com/ebaymotors/NEW-6...QQcmdZViewItem
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-25-2006, 10:07 PM   #6
Ron 586
RIP Mr Ron
Ron 586's Avatar
Take the manifold off and look for the casting number. Unless you are sure that the engine is original you need another one like the one that's on it so you don't have to modify the exhaust to make it fit. Good luck.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 07-25-2006, 10:50 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Does it look like this one?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-30-2006, 12:43 PM   #8
l79m20
Thanks vettevet, the original engine is still in the truck and the Number on th e manifold is 3905364 RH....someone told me that these motors are know for cracking manifolds....any truth to that. Am looking for an original part to replace the broken side..............Joe....By the way I own a l79 65 corvette coupe
Old 07-30-2006, 04:23 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's not so much that the casting is weak, but it IS 34 years old.
