Old 07-25-2006, 05:27 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Has anyone done this to a Blazer gas tank?
On my Blazer tank, the fuel filler inlet piece unbolts from the tank. It looks like it might be studs, but I can't really tell if they are studs that are welded/part of the tank, or if they are bolts that will fall off inside the tank if I take the nuts off.
I would like to take it off so I can cut the 1-3/8" tube off and TIG on something larger. Has anyone ever removed this piece?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-25-2006, 05:37 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Has anyone done this to a Blazer gas tank?
Well mines plastic, lol, but I'd rather have the metal one, I dunno, ttt
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-25-2006, 05:43 PM   #3
Primered_69
Primered_69's Avatar
I have also thought about this but I have a plastic one. I thought about capping the old hole and installing a bigger filler hole in a better placement using a gasket and bolting it in place.
For a steel one there should be no problem doing this as long as it is a new tank. i would never try to weld on one that have ever had any gas in it
You might want to consider these these questions in the swap:
If you moved the location to a better location to avoid the frame rails and to allow easier filling, would it have any affect on the fuel sending unit and its operation?
Could you use the filler tube fom one of the behind the seat tanks?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 07-25-2006, 05:46 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Good question. I didn't unbolt mine, but this is how I enlarged mine to a 2-1/8 or 2-1/4" diameter?? Can't remember, whatever a '96 silverado fuel filler is. I used two muffler pipe pieces.... I hope they don't rust and fall apart
It's probably going to fill slow, but at least the hose will fit now
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-25-2006, 05:47 PM   #5
glock35ipsc
It is a new tank, but that doesn't really matter. The location is OK, but I need to make it larger. That is why I want to know about the studs/bolts, whatever they are, so I can remove that piece from the tank. I need to remove the old tube because it is 1-3/8", and replace it with a piece of 2" tube.
Bob
Old 07-25-2006, 06:48 PM   #6
John Fabris
TOTY 2006
John Fabris's Avatar
They are either welded or pressed into the tank, so unbolting them will not cause them to fall into the tank. Then, you will find that the tube is soldered to the tank.
I have had my tank open and out in the sun for over a year before I heated up the solder to remove the tube. I then cut it and rewelded the tub at a new angle, and reapplied the solder to the tube mounting location. I also moved my vent tube from in front of the filler tube to back of the tank.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 07-25-2006, 07:08 PM   #7
You can apply heat to a fuel tank if you pump exhaust gas into it at the same time.The carbom monoxide starves the oxygen out eliminating the chance of ignition.If you`re removing the neck,you can get anything that may fall in (shouldn`t) back out.
Old 07-25-2006, 07:22 PM   #8
glock35ipsc
It still a new tank, so there is nothing there to ignite.
John, thanks for the info, that's exactly what I was wondering. Did you have to apply new solder, and if so, what kind did you use. Also, what did you use for the tubing that is inside the stake pocket? I went to the muffler shop today and they said the smallest they can get is 1-1/2". I found some 1-1/4" EMT conduit, but that is also 1-1/2" OD. That's why I want to swap out to something bigger.
*** EDIT - OK, I looked at it again. What I thought was a heavy coat of galvanizing must be the solder? I tried to loosen up a nut and it wouldn't budge. So I guess I need to heat the solder, unbolt it, then heat some more until it comes off?
Bob
Old 07-25-2006, 07:44 PM   #9
chevyboy55
chevyboy55's Avatar
My son & I capped his filler,had a new one made to the size of the filler hose at a muffler shop then welded it(wire feed) in place where it would be a better fit.We then pressured tested the tank to check for leaks. I don't have any pics right now because the truck is at the painters!!!! WOO HOO!!!!!!
If you need I can take some this weekend when we are there working on it & post them.
chevyboy55 is offline   Reply With Quote
Old 07-25-2006, 07:51 PM   #10
69gmctowrig
You CAN weld on a tank that's had gas in it. You just have to be careful. I've been digging up underground gas tanks in gas stations and back yards for years and I can tell you from experience that not only can you weld on them, you can cut them with a torch. The gas isn't what will kill you, it's the fumes. so, if the tank is empty, fill it with water, or take off the gas cap, drain all the gas and carefully (match on a long stick) burn off the fumes.
69gmctowrig is offline   Reply With Quote
Old 07-25-2006, 08:16 PM   #11
glock35ipsc
I remember the last underground gas tank I dug up. We had to put XX amount of dry ice in it before we could start digging.
Chevyboy55 - A pic would be great!!!!!
Bob
Old 07-25-2006, 08:22 PM   #12
71swb4x4
71swb4x4's Avatar
I have done something similar. I took my old nozzle off the old tank and put it on the new tank. The old nozzle was bolted and soldered. It was easy to get off.
The new tank used either high heat solder or some sort of brazing sticks. I could not get it off with my propane torch. I took it to a wleding shop and they removed it for me.
On both tanks the sealer (solder or whatever) had to be heated before I could get the nuts off.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-25-2006, 08:45 PM   #13
69gmctowrig
Yeah we did that one time. Takes wayyy too much dry ice for a 2000 gallon tank though, ended up digging it up anyway and poking holes in it with the backhoe bucket.
Old 07-26-2006, 02:56 AM   #14
John Fabris
TOTY 2006
I have a box of many different types of solder but I don't remember which one I used. I thing I tried a couple and as long as all surfaces were clean, and heated the same it worked. Can't see any reason why lead can be used instead.
AS for the the filler tube inside my stake pocket, goto a good parts store (Napa for example) and ask for the fuel tank filler hose, it is costly ($10 a foot I think) and for the elbow I went to a muffler shop and had a piece of tubing bent (gave it to me as a trade for a 12 pack of mountain dew)...
Let me know if that helps!!!
John Fabris
67 C10 SWB
Old 07-30-2006, 08:23 PM   #15
chevyboy55
chevyboy55's Avatar
Glock
Here's the pics ,sorry it took so long, but today was the first chance I've had to get to the painters.
Old 07-30-2006, 08:50 PM   #16
glock35ipsc
Very cool! Thanks for the pics, that gives me some ideas.
Bob
