Rebuilding 1 at a time
Electrical question
I am having a problem with my turn signals. They were working fine but now they flash about 5 times too fast. I have replaced all the bulbs and that still didn't fix it. But all the other lights work fine, headlights, break lights etc. Any suggestions?
71 cheyenne lwb 383 stroker 2004R tranny Factory ps, pb, air http://smg.photobucket.com/albums/v3...t=101_0059.jpg 66 Nova SS L-79 327 m21 http://smg.photobucket.com/albums/v3...t=101_0042.jpg |
Re: Electrical question
I have seen this before if you have a HD flasher in it.....other than that no clue....
![]() Join Date: Jul 2006
![]() I agree. Sounds like the flasher. |
flasher relay
Kevin 1967 C-10 swb fleetside 1968 C-10 stepside 1999 Z71- sons dd 1999 2wd silverado-my dd 2003 Tahoe- wifes dd |
Wouldn't a HD flasher cause it to flash slower? There is something draw too much current and causing the flasher to flash to much. I know some people would put the HD flashers in because when they hooked up a trailer the trailer blinker lights would draw too much current for the smaller flasher and cause them to flash way too fast. The HD flasher would cure this because the bi-metal strip in the flasher was heavier.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
its all about the +6 inches
you are correct, the HD ones would go agonizingly slow.
Quick troubleshooting tip, swap the two flashers around. You have one for the turn signals, and one for the 4 ways. if you swap and they work properly, replace the flasher. If it still actsd stupid, then something is wrong, and what ever it is, it is placing a huge load on the flasher. It would just about have to be a messed up turn signal switch since it is doing it on both left and right. |
