Old 07-10-2006, 09:29 AM   #1
ben@speedbarn
Done yet?
ben@speedbarn's Avatar
Question NP205 won't shift into 2wd
I have a 76 GMC 3/4 with a sm465 tranny and a np205. The only shift positions I can get into is 4lo(all the way to the front), neutral, and 4hi. There is no position I can get into that the front driveshaft isn't engaged(except neutral). Is there any adjustment on the shift linkage or any common problem that might be the cause of this?
Thanks,
'76 k2500 -- almost done...
ben@speedbarn is offline   Reply With Quote
Old 07-24-2006, 02:59 AM   #2
Americanrider
Re: NP205 won't shift into 2wd
Worn out shifter linkage is my first guess. Get under it w/ a flash light and have someone else shift it.
Americanrider is offline   Reply With Quote
Old 07-24-2006, 12:23 PM   #3
tgh117
Crazy
tgh117's Avatar
Could you have a hub sticking instead that would lead you to believe its missing 2 HI?
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 07-24-2006, 12:49 PM   #4
ben@speedbarn
Done yet?
Nope...they definately aren't sticking.
Old 08-07-2006, 12:27 PM   #5
ben@speedbarn
Done yet?
Well I checked out the linkage and it looks fine. Both rods are moving in and out fine. Must be something on the inside of the case I guess??
Old 08-07-2006, 07:45 PM   #6
b454rat
2wd on a 205 moves one of the shafts, not both of them. It's only a very small move. Put it in 4wd high, then just tap the shifter alittle and see if it goes in that way. The 205 in my truck is like that, think your in 2wd and it's still in 4wd. Mine is a PITA to get in and out, while the one I'm putting in, you can shift it with your fingers at the shaft, it's that easy.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-08-2006, 09:14 AM   #7
ben@speedbarn
Done yet?
I'll look at it again....it seems that all the way front to back it moves both rods the same amount. I've tried moving it as little as possible but it is either in 4wd or neutral. No matter what I can't get it in 2wd. There doesn't seem to be any adjustments on the linkage either. I will probably end up rebuilding it in a few months cause it is leaking from the front seal and somewhere else in the back.
