76 Gauge Cluster/Bezel?
Hello,
My buddy just got a 76 1/2 ton for the motor. Would the gauges and bezel work in my 82? thanks, Harvard |
7000 #'s of american IRON
Re: 76 Gauge Cluster/Bezel?
I believe they will. I don't believe they changed much in the cab
Stepsides RULE
I think you might have to use the printed circuits.... does the 76 have an ammeter or a voltmeter?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
I'd assume it'd be a voltmeter..thats what my 77 has
#5 | |
Stepsides RULE
Somebody 'round here is gonna know for sure.... you can always check out www.73-87.com, I'm sure the answer and a 5 page explanation is on there.
Happy to be here
![]() Join Date: Mar 2000
No, it will not work correctly. The 76 still had a mechanical oil pressure guage and an ammeter (amps) rather than a voltage guage.
#7 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
1978 had electric oil sending... 78-up is the only bolt in for the 81-87(91).
EDIT: here is the info you want: http://www.73-87.com/7387garage/inte...achometers.htm
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 08-01-2006 at 04:10 PM. |
Thanks Guys. Dang it, I had it for free. Still havent said no though. Would the bezel work? If so, I can keep then bezel and get rid of everything else.
Thanks, Harvard |
yes, the bezel will work. Just dont be surprised if the top left corner breaks off. Apparently thats a normal occurance.
#11 | |
Stepsides RULE
Slots go on anything!
If it does, just glue it back. The later (81-up) dash pad comes out further, and will help hide it.
1974 Jimmy- 5.3/4L80e/NP241 |
#13 | |
Until Seventy Times Seven
...or, since it is free, take it all and keep the gauges and other parts that you may need in the future, i.e. like if the fuel gauge goes out.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Done yet?
My 76 has the mechanical oil but the voltmeter. I tried fitting an aluminum bezel from an 81 on my 76 and it wouldn't fit right. But if it's your friend and it's free it is worth a try.
'76 k2500 -- almost done... |
#15 |
NOTE:
wiper switches MAY BE different. |
#16 |
Thanks guys. Just my luck. I am taking it any way. Just in case, I happen to know of anyone that needs something, or to just have extra parts!
Harvard |
#17 |
Real Men Wear Orange
The wiper switch should be the same. I have two '82s and they both have the switch on the dash...not the column. And the high beam foot button thing.
#18 |
I know on my 76 I have a junk yard 85 Bezel and it DO"NT work. Well' let me rephrase that it will work but it bends at a diffrent form . The reason why I know this is because the Bezel is off A 85 and the lower half is off A 76 THEY DO NOT CONFORM TOGTHER CORRECTLY.
FOR BEFORE AND AFTER PICS AND A PIC OF MY BIKE AND MY WIFE (YEA RITE) CLICK ON MY Photobucket |
