Old 08-04-2006, 08:03 PM   #1
laidout86
control arms needed?
hey guys whats goin on...i just recently put on my new rims/tires and it lifted the front end up..im runnin a 265/35/22 and was wondering if im gonna need tubular control arms to get the front to lay out..right now the crossmember is about 2 inchs or so off the ground..i want to get the crossmember laid out first so i dont have to make a bigger z than have too...thanks alot guys!
laidout86 is offline   Reply With Quote
Old 08-04-2006, 10:27 PM   #2
XXL
Seņor Member
XXL's Avatar
Re: control arms needed?
Tubular control arms aren't going to give you any additional clearance.
XXL is offline   Reply With Quote
Old 08-05-2006, 12:32 AM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
If you get plenty of lift I would check into cutting down the bottom cup a bit. Just make sure it wont rub if you cut it down. Im assuming you have spindles already and an upper plate, lower cup setup.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 08-05-2006, 01:39 AM   #4
laidout86
yea have that already and the bottom cup is cut down to 1 inch already
Old 08-05-2006, 04:31 PM   #5
7deuce
Sold! 2 days after finished
7deuce's Avatar
Take out the lower cup and weld a flat plate in the control arm. That might get you another inch.
7deuce is offline   Reply With Quote
Old 08-06-2006, 12:50 AM   #6
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
If the truck is an 86 you dont need a lower cup just bolt it to the LCA. They are big enough. Just make sure to debur it and clean it all up.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-06-2006, 04:42 PM   #7
laidout86
i just ordered lowers so as soon as i get them im gonna put them in and see if it helps....im gonna put them in without the cup also so.....
Old 08-08-2006, 11:29 AM   #8
Tony@AirRideTech
Junior Member
Are you also running dropped spindles on the truck?
Tony@AirRideTech is offline   Reply With Quote
Old 08-08-2006, 04:19 PM   #9
Shane
Shane's Avatar
Shane is offline   Reply With Quote
Old 08-08-2006, 05:04 PM   #10
laidout86
yea i got 3 inch drop spinedles on there with a suicidedoors upper plate with a slam re-82
