67-72 A/C Flapper Question????
I am trying to install factory A/C in a non factory A/C truck. I've looked through the Service Manual and Factory Assembly Manual and cannot find anything about a cutout for the flapper that fits in the cowl in the Factory A/C system. Does anyone know if I need to cutout for this, and if so, what is the best way to do that? Better yet, does anyone have any pictures? Thanks for your help.
Re: 67-72 A/C Flapper Question????
Check this link out, I think it has what you want.
http://67-72chevytrucks.com/vboard/s...d.php?t=207799
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
No cutting required. Just get a donor flapper. Take a good look at how it was mounted in the junk truck. Make note of the size of the holes. Your truck has dimples from the factory on where to drill the three holes. The flapper is the easier part of this swap.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Here are some pics of the flapper door as it is installed.
Jim |
TOTY 2006
![]() Join Date: Dec 1999
Hey Jim, that spring is in the wrong hole!!
Thanks so much, those pics will help a bunch!
Good eye John!
I did move the spring before I installed the cowl clip. Jim |
