lug conversion
Hey Fellaz,
This question concerns my 84' Sierra 2WD. In a further pursuit of getting my truck in a status I am happy with, I have come to swapping in a new diff. My truck was equipt from the factory with a 10-bolt non-posi 3.08. I am also just in the process of doing a 1-ton axle swap in my 80 4x4 silverado and will have a 12-bolt posi 3.73 from it that will no longer be used. The 12-bolt is the perfect candidate for the swap because it's posi, and has all the proper dimensions and spring perches to just bolt it all up. My only issue with doing the swap is the fact that my Sierra is a 5-lug truck and the donor 12 bolt diff is 6-lug. ![]() ![]() I have also had plans of slamming this truck too, so I have also thought about an axle flip. How much drop will that give me? The front drop will be matched accordingly. Thanks for any input.
68 GM-Chev Sierra Grande 383/700r4 84 sierra half LWB layin' frame soon 350/350 1980 chevy silverado SWB 4x4 12" lift, D60F, 14Bff, 40" TSL's 454/350/205 What a wonderful stable of vehicles to have when gas is +$1.00CAD/L. ![]() |
Gentleman Jim Driver
Re: lug conversion
Swap the rear axles. Find a 2wd 12 bolt and get the axles and brake drums.
The 4x4 front brakes parts and spindles won't fit the 2wd.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
7000 #'s of american IRON
Re: lug conversion
would GM have been nice enough to tap the axles for both patterns? I doubt it, but figured it was worth a try...
Re: lug conversion
Leave The frontend alone. If I read correctlly. You are swapping a 6 lug in place of a 5 lug rearend?? If this is the case . Just take your axle's and drums from the 6 lug and have them redrilled for the 5 lug bolt pattern. Any respectable machine shop should be able to do this. And isn't all that expensive. considering the time and money you'll save from swapping frontend parts.
I am doing this very same thing with my truck. Hope this helps. |
#5 | ||
Re: lug conversion
![]() Quote:
![]() But anyways, you guy's have filled my head with quite a few new ideas. ![]() ![]()
87 Wanna Be K30
Re: lug conversion
The only problem with that is the fact that 2WD trucks never came with 6 lug axles. Otherwise it would have worked fine. If you get the axles and drums drilled it wont hurt them at all. I would say that would be your best bet. But thats just me.
-Scott |
Re: lug conversion
67-70 chevy trucks were 6 lug and 2wd if i remember correctly, might look into swapping parts from one of those trucks over to yours... I am not sure on the compatability... but just another idea....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
