Old 08-09-2006, 01:45 PM   #1
68jimmy
68jimmy's Avatar
Diagram for a propotioning valve
Does anyone have a diagram of a proportioning valve for a 72? I removed the large fitting on the rear of the valve and the spring pressure popped out 3 pieces I need to re-assemble it but I'm not quite sure of the order in which to put the parts back in... Any help appreciated!
BTW: It is a disc/drum valve...
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 08-09-2006, 04:57 PM   #2
68jimmy
68jimmy's Avatar
Re: Diagram for a propotioning valve
Ttt
Old 08-09-2006, 10:29 PM   #3
Green Machine
Green Machine's Avatar
Just had one of mine apart a few weeks ago to clean out some gunk and get freed up. Can you post a pic of the parts, can't describe assembly order from memory right now.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-10-2006, 09:56 AM   #4
68jimmy
68jimmy's Avatar
Here are the pieces that popped out when I removed the rear fitting... So if you imagine the prop valve is on the exteme left do I have the order of the pieces correct?
Thanks!
Old 08-10-2006, 11:54 AM   #5
Green Machine
Sorry - That looks quite a bit different from the one I had apart, since this is a safety related item, I would rather not guess how that one goes together.
