Old 08-10-2006, 10:13 AM   #1
Yukon Jack
Yukon Jack's Avatar
Question Which cancel cam plunger do I need?
I am putting a van tilt column in my 69 K20 and will likely be using a Grant steering wheel with it.
The cancel cam on the van tilt is missing the plunger and I know there are at least two styles. One is just a metal plunger and the other is a plastic piece, that goes where the metal plunger would be, with a spring on the plastic end then a wire lead that goes out of the plastic piece.
Any idea which plunger I should be using?
Here's a couple pics of the van tilt's cancel cam.
Any suggestions on plunger style I should use or if I should be using a different style cancel cam? As you can see I don't know anything about them
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-10-2006, 10:40 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Which cancel cam plunger do I need?
you have the right cancel cam. With a grant GT, you'll want the one with a wire.
Old 08-10-2006, 11:10 AM   #3
Yukon Jack
Yukon Jack's Avatar
Thanks Andy.
Old 08-10-2006, 12:24 PM   #4
bryanw1968
bryanw1968's Avatar
Man that's a nice truck!
bryanw1968 is offline   Reply With Quote
