Old 10-21-2005, 12:40 AM   #1
longhorn71
longhorn71's Avatar
gauge cluster swap
I have an 87 blazer with the idiot lights dash and i want to swap to gagues.Anybody know what wores need to be moved around on the connector?I was told it was a plug and play deal(with sender swap as well)but the temp gauge moves with the left singal light indactaor and the volt gauges is the right indacator so much for plug and play
longhorn71 is offline   Reply With Quote
Old 10-21-2005, 05:45 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: gauge cluster swap
Definitely not a plug and go swap. I use a Haynes manual for swapping.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-23-2005, 04:30 PM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
different wiring behind the cluster. I'm SUPOSSED to be the dash guru here and the last IDIOT light swap i did ,on a truck to sell, i actually installed all cheapie 2" aftermarket gauges into. I didn't feel like buying all the senders and looking up all the differnt wires . some of the colors even changed from Idiot light to gauge wiring. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 10-23-2005, 06:15 PM   #4
tkeduk8r
tkeduk8r's Avatar
well, its actuallypretty easy, just tedious... I did the swap on my 74, and only a few wires were different... I had both clusters out and compared the circuit board patterns from one to the other... each elect. gauge needs a hot, ground, and the sending wire.. many times the hot and ground circuits connect between more than one gauge... if there is only one dedicated connection between the dash connector and the gauge, its the sender wire... I had the diagram of how i did it, but recently discovered it had coffee spilled on it and is now pretty much unreadable... but if i can do it you can too.. you will need the gauge approprate sensors for the oil pressure and the temp gauges to work properly... if you have any questions while doing htis let me know.. OH i made the changes by using a jewelers screwdriver to change the position of the wires in the male dash connector...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 10-23-2005, 07:18 PM   #5
crossy
crossy's Avatar
Originally Posted by tkeduk8r
well, its actuallypretty easy, just tedious... I did the swap on my 74, ... but if i can do it you can too..
--Mike
Mike Mike Mike, c-mon your a daggone auto TECH teacher.
hey i see by your sig that you dropped a 305/200 in place of the old straight six.
drop me line at the same old all4trux@snip.net and let me know how your making out.
As long as you are still in Minn. go by the Vikings field and ask them what the heck happened to them this year ?????????? Kick Dante in the A$$ and tell him it's from me--then run of course. Dont worry there is no one on the team this year that could catch you :-)
I've been waiting for those losers to win a super bowl for me for more years than most of the guys on this forum have been alive.
DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 08-13-2006, 03:46 PM   #6
wildmanaaron
--Mike
I have the Haynes manual that alot of people have recommended,but I cannot seem to find all of the answers. I have a 1981 Blazer with the two dummy lights at the bottom. The previous owner had installed two Sunpro gauges for the Temperature and the Oil Pressure.
The guage cluster that I bought to replace the dummy set-up is from a 1987 TBI Truck.The way that the speedometer is held on the back of the gauge is different between the two. The one that came out of my Blazer attaches to the plastic housing, while the other cluster has a clip on the back of the gauge itself to hold the cable in???
wildmanaaron is offline   Reply With Quote
