08-14-2006, 12:50 PM | #1 |
Re: 6 volt slow cranking
the most common mistake found with 6v systems is using 12v cables witch are smaller gauge and won't carry the amps required to run the starter 6v battery cables are almost twice the diameter of modern 12v cables// also looking and seeing that grounds are in place isn't the same as disconnecting cleaning and establishing a good ground
