08-16-2006, 12:14 AM | #1 |
Custer had a plan too.
Rams Horn Stud Replacement?
Is it possible to replace the studs on rams horn manifolds? Some of the studs are stripped/rotted on my truck. If it is possible, how is it done?
Thanks!
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ) 05 Subaru Outback for mileage |
08-16-2006, 12:19 AM | #2 |
Re: Rams Horn Stud Replacement?
I took mine to a machine shop and had them done.
08-16-2006, 09:45 AM | #3 |
Active Member
You will need to use a torch to heat up and break the rust.Then a visegrip usually does the job. Just my .02 Rick
08-16-2006, 10:27 AM | #4 |
Senior Moment
If you have never done this before, take it to a machine shop and let them do it. If you break them off and try to drill and mess it up it will cost you double. If you break off an easy out in it ,it will triple the cost. Save yourself some time and money and let some one who knows how to do it right do the job.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
08-16-2006, 11:22 AM | #5 |
I have done this myself. You need and oxy-acetylene torch. You heat the manifold ear red-hot then twist the stud out with a vise-grips.
Propane and other type torches don't heat the manifold up quick enough. You'll for sure twist it off in there making a bigger mess. If you don't have an oxy-acetylene torch, ask a machine shop. They usually only charge you a couple of bucks.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
