False Lies
air bags or coils with dropped spindles?
ok, heres what i want to accomplish.
an awesome ride hight for a daily summer driver.. =cheap costs. i already did the no-no of cutting my coil springs.. but i couldnt afford much better, but now im thinking maybe i should go down the proper road, as i was to lower it another 2 1/2", to make the top of the tire at the bottom of the fender. now, i dont know whether i want to buy some air bags (hook them up to valve stems to be later hooked to a compressor down the road), or some drop spindles. im looking for the best, cheapest way to get results... (if possible) thanx for your help!!! -kyle
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... |
Re: air bags or coils with droped spindles?
I would put bags in. reason for them is. When you park at a show you can drop your truck low. Plus you get that riding on air feel. That is what I am wanting to do to my truck.
My opinion. |
The LuvShack Garage
Bag it Baby
![]() But ............................................... Drop coils will be alot cheaper ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
False Lies
im leaning towards bags too i think
Happy to be here
![]() Join Date: Mar 2000
Coils are the cheapest way to get a static drop. Spindles are better because they don't effect the ride but cost a little more. Bags will offer you adjustability in your height.
My suggestion would be to buy the spindles now, and add bags later when you can afford a complete set up... ![]()
False Lies
guess what!! my girlfriend's dad had 2 firestone bags that he said i could have.. no cost!! muhuhahaha!!! so, im gonna bag it. -kyle
uhhmmm ... you're gonna need more than just the bags ... tank ... brackets ... valves ... compressor ... air line ...
the bags is one of the least expensive components in a "bag" system. |
False Lies
well, for now, all im hooking up is 2 bags in the front. there is some line that came with them, more than long enough attached to some valve stems. so, therefore, all i have to fabricate or buy is some bracket/adaptors to put in place of my coil springs. this should work right??
Happy to be here
Ok, so your going to do this on the cheap. Go to www.***************** and buy two bag plates, and two bag cups. This will give you what you need to remove your coil springs and have the start of a system.
Make sure you route your line away from anything that will rub a hole, or melt the line.
![]() Join Date: Apr 2005
Just remember "cheap" and "safe" don't always go together. Anytime I do suspension, steering or brakes - I hesitate to put those 2 words in the same sentence. JMHO.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
False Lies
i've took everything into consideration, and decided to go with some drop coils, the truck sits about 2" lower than in the first picture at the top of the page, im pretty happy with the results.. except, the rear needs to come down. i attached some pictures of the way it sits now. i put a 5" drop lowering kit on it (shackles and hangers)... i shoulda put a flip kit in... to lower i think im gonna make some brakets to put those air bags in, and run just a mono leaf spring.. and of course notch the frame. then i can adjust the hight, and make er what i want it to be.. correct?
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... Last edited by steemin_ehman; 08-15-2006 at 02:16 PM. |
Outlandish Trends - FL
Gotta love the milk crate seat!!
Here's my $.02. Spend the money now and do the spindles. You're going to want them later anyway. You can get a good set for about $250. Check McGaughy's or Belltech. As said, you can run bags, but you're gonna need upper plates, bags, lower cups, fittings to go into the bags and some line and you can run the line into 2 schrader valves to fill when you need to and then you can get a portable air tank to fill them, but realize that the front end is heavy and it takes a lot of psi to fill them up. On my '67 it takes 100psi in my tanks to raise the front end. On a portable 3 gallon tank you may or may not be able to get enough air in their to fill the bags 1 time. Forget about filling it twice. And if you have any kind of leak at all and all you have is that portable tank, you're gonna be screwed and will be left stranded. And that sucks! Good luck, but I'd go static for now, whatever you decide to do, don't skimp out on suspension/chassis components. It's yours and everyone else on the road around you's safety at risk. Keep that in mind.
-Bret 67 short-fleet sold! |
False Lies
Re: air bags or coils with dropped spindles?
alright! thanx for the information!!!!!! much apreciated. static drop is what its gonna be... its the best i can afford right now, and suits my needs perfectly. -kyle
