Old 08-18-2006, 04:38 PM   #1
69CvyPickup4x
69CvyPickup4x's Avatar
alternator q need answers ASAP
this question may have been asked before but i couldnt find it in the search, anyway i just swaped a bbl 454 and i have a mean green alternator on it, now i have everything wired up except the alt. because i dont know what to wire it to. so theres one threaded bolt coming out the back.. thats the recharge hook up that goes to the batt. right?? and theres two other wires coming out of it with a connector on the end.. cut the connector off and wire it to what?? im anxious and want to run it, that about the only thing holding me back.. THANKS ALOT FOR ANY HELP!!
69CvyPickup4x is offline   Reply With Quote
Old 08-18-2006, 04:51 PM   #2
69CvyPickup4x
Re: alternator q need answers ASAP
i have hei with an msd ignition, all of it can off a 78 suburban
Old 08-18-2006, 10:35 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Go to this thread and scroll down to the engine related electrical Faqs.
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
There are several that will help you. Do you have an external or internal voltage regulator. I suspect that the alternator has an internal regulator if it is the 454 original alternator. Your truck should have an external regulator mounted on the left hand side of the radiator support. The alternator conversion by Todd the odd explains how to convert and wire the newer style alternators.
You will find that your truck originally came with a points style distributor and you have an HEI for it. There is a FAQ thread on this conversion also in the same group. Good luck and there are plenty of guys willing to help if you need it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-18-2006, 11:05 PM   #4
truckdude239
truckdude239's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
