Old 08-17-2006, 04:17 PM   #1
Bob D
Rolled on Paint Club
Bob D's Avatar
Front brake drum ?
I had to grind 3 rivets off of each of my front drums to get them off. Does this mean that I had the original 36 year old drums on the truck and the PO's have been pulling the hub off the spindle to change shoes??
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 08-17-2006, 04:22 PM   #2
cdowns
cdowns's Avatar
Re: Front brake drum ?
what's unusual about that??
Old 08-17-2006, 04:44 PM   #3
Bob D
Bob D's Avatar
I guess that is what I was wondering. Is it unusual or fairly typical?
Bob
SB 355ci.
Smog heads
Summit 1102 cam
Old 08-17-2006, 07:49 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen it quite a bit.
The replacement ones at the parts store suck... you'd be better off locating old originals that can still be turned.
Old 08-18-2006, 07:29 PM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
It seems that was GM's way of making you inspect or at least look at the wheel bearings. I think I remember the service manual saying the front wheelbearings should be inspected and serviced at the same time the shoes are replaced.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-18-2006, 09:00 PM   #6
cdowns
cdowns's Avatar
back in the day oldtimers would rather go spend half a day in junkyards searching for originals that were usable instead of grinnding the rivets for "replacement drums" or in my fathers case send me
Old 08-19-2006, 12:59 AM   #7
Longhorn Man
So instead of getting the made in china junk drums, send cdowns to the junk yard, he'll get them for you.
Old 08-19-2006, 04:28 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Probably just a P.O. who did his own brakes or had a quality shop do it.If the shoes are always replaced before they wear to the rivets then they wont need turning.I have always pulled the wheel bearings when doing a brake job so I could repack them so they may have been pulled hub and drum together so the wheel bearings could be serviced.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-19-2006, 04:45 PM   #9
Bob D
Bob D's Avatar
Thanks for all the replies, Guys.
I am reusing these drums since they are in great shape. The rears are a different story. One drum was noticeably lighter than the other and appeared to have been ground too thin. So, I have one drum, all shoes, spring kits and 4 cylinders on order.
Bob
SB 355ci.
Smog heads
Summit 1102 cam
