Old 08-20-2006, 09:24 AM   #1
gator2511
gator2511's Avatar
Hood to cowl gap???
How much gap should be between the hood and the windshield wiper cowl? My truck looks wide but I'm not sure what it should be.
gator2511 is offline   Reply With Quote
Old 08-20-2006, 10:21 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hood to cowl gap???
Mine is between 1/8" and 3/16".......
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-20-2006, 11:15 AM   #3
gator2511
gator2511's Avatar
Well mine is between 5/6 and 3/8. There doesn't appear to be any clearance on the front of the hood to move it back any. I'd like to close it up a little if I can. Any advice on how to do this and what to look for?
Old 08-20-2006, 11:58 AM   #4
LONGHAIR
This should probably be in the "Paint & Body" forum.........
If it only needs to move back (not up or down too) it may be as easy as moving the hood back on the hinge mounts. You may need to adjust the latch in the front of the hood too. It may push/pull you away from your other adjustments.
Do yourself a huge favor before you start though. Draw a line around the washers of the mounting bolts with a Sharpie marker before you loosen anything. This way you can get back to where you started if you get too wackey.
LONGHAIR is offline   Reply With Quote
Old 08-20-2006, 12:04 PM   #5
gator2511
gator2511's Avatar
Did It!!! Had to shim the cowl up on one side to make it look good. Its all better now THANKS.
