#16876
Need guidence w.LOWERING '63 C-20
I need any advise possible in lowering my '63. Its a 3/4 ton. Obviously I do not care if it remains a 3/4 ton. Im looking at cataloges and see that all of the lowering coils are for a C-10 model. Nothing for a C-20. Does this indicate that the springs are 1/2 ton rated and will fit either suspension? Im not in a financial situation to put on drop spindles. I have to stick with lowering coils.
Can anyone tell me what the best front/rear drop ratio is, and where to get the coils? I want to go as low as I can with the use of coils. I want the stance to be level, or slighly lower in the front. ![]()
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
Re: Need guidence w.LOWERING '63 C-20
i cut the springs on the front of my half ton.i don't know if that will work on a 3/4 ton.btw www.earlyclassic.com has conversion spindles if you want to change to five lug.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
Cantankerous Geezer
If you aren't needing the 3/4 ton suspension, get a front crossmember and rear end from a 73+ 1/2 ton. It might take a little adapting, but it will make lowering a lot cheaper. The other low dollar option is to cut or heat the coils and remove leafs from the rear.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
I'm about to attempt the same thing with a 62 C20. Switching out the frame to a 85 chevy 1/2 ton. Was able to pick it up with power booster, tilt colum, and drive shaft. Planning on building a v8 for it. LS
#16876
I decided to use 1/2 ton drop coils. It was a pain primarily due to chipping 40 y/o undercoating from everything. I went with a 4/2 drop. It looks pretty good. It was as low as I could go without having to change spindles and doing a disc brake convert.
