Temp.Sensor ?
I forgot ...which head does the temp.sensor go in? Also,what goes in the other head? The threaded holes look the same and I can't remember...Thanks
Re: Temp.Sensor ?
the drivers side was for the temp gauge and the passinger side was either a plug or a temp/check engine light.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
Re: Temp.Sensor ?
Passenger cyl head originally had a TCS (temperature controlled spark) switch used to control the ignition vacuum advance. If this early emissions system has been removed from your truck, just install a plug. Keep in mind that these are pipe (NPT) threads and a SAE bolt won't fit.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Re: Temp.Sensor ?
Thanks a lot ...this board is awesome!!!!!
