Old 08-23-2006, 04:32 PM   #1
raoul.duke
Sandwich: Club
raoul.duke's Avatar
Temp Gauge Position vs Actual Temps
Been getting some high temp readings (to the first 'H' bar) out on the highway and have been reading the posts on bad sending units, which made me wonder-
How do the gauge positions correlate to actual coolant temperature? Example- a meat thermo in my radiator after idling for ~20mins. showed 170 degree coolant temps, gauge was right at the middle. Does this sound right? If so, what is the coolant running when it nears the H side? What temp triggers the 'Temp' idiot light?
Read an earlier post where someone said they were running 160 or so and they were barely up off the C line, which made me wonder if maybe I'm not running as hot as it looks.
raoul.duke is offline   Reply With Quote
Old 08-23-2006, 05:48 PM   #2
Yeller68
Active Member
Yeller68's Avatar
Re: Temp Gauge Position vs Actual Temps
I've been having some of the same issues myself. Temp gauge showing in the red, but I really don't think it's running hot. I'm going to try the meat thermometer myself, good idea.
BTW Raoul love your avatar. One of my fave movies of all time...
"Now, what's it gonna be young feller? You want I should freeze or get down on the ground? 'Cause if'n I freeze, I can't rightly drop. And if'n I drop, I'm gonna be in motion"
Yeller68 is offline   Reply With Quote
Old 08-24-2006, 06:00 PM   #3
raoul.duke
Sandwich: Club
raoul.duke's Avatar
ttt
Noone has any idea what the temp should be at the midpoint reading of a 'calibrated' C/H temp gauge? It's a '72, if that matters any....
Old 08-24-2006, 06:23 PM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Mine runs normally right in the middle, 180 degree thermostat, fairly new sender, gauge ground is good. I can always tell when my stat hasn't warmed up enough to open, because the guage will go towards the "H"; and then when the stat opens, it goes to the middle. Usuallt only does this when I have the heating water valve to the heater core in the off position. I would venture to guess that they were calibrated to run in the middle under normal conditions, etc.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-24-2006, 10:45 PM   #5
powell72
powell72's Avatar
When my truck is at 180 it runs 1/4 of the way up, right where the red starts with my new gauge. The old one was 3/4 of the way up at 180, with everything else the same.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-25-2006, 06:21 AM   #6
dwaite72lnghrn
I have the stock temp gauge in passenger head and aftermarket in the driver side. At 180* in aftermarket the stock is just at the left mark \\ on the stock. At 200* it is about a 1/4" above the left \\. At 230* it is at the right /red side. This was in the 402bbc. The 502bb is the same except I have never been to the red mark yet.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 08-25-2006, 05:11 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Your's sounds like it's working right. 160-180 in the middle. The H side should be about 220.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
