Old 09-01-2006, 10:13 PM   #1
deer slayer
truck wont start need help please
72 k20 350motor turn the key nothing only the brake light comes on and the temp light dont come on all fuses checked good all the ones seen anyways ive got 12volts at the battery any info would be greatly app.
thanks jeff
deer slayer is offline   Reply With Quote
Old 09-01-2006, 10:19 PM   #2
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: truck wont start need help please
check and see if you got power to the starter, maybe see if the fusable link is blown however i would think that nothing would work if that were the case
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 09-01-2006, 10:21 PM   #3
deer slayer
theres power to the starter
Old 09-01-2006, 10:26 PM   #4
lilpup69chevy
67-72 parts finder
does it have a solenoid you can jump across??? also like i said try the fusable link located close to the battery
Old 09-01-2006, 10:31 PM   #5
neonlarry
neonlarry's Avatar
When you turn the key to start do you have power to both large terminals on the starter or just one?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-01-2006, 10:50 PM   #6
deer slayer
neonlary there is only one big terminal on the solenoid
lilpup yes it has a solenoid but it has two small post which do i use
Old 09-01-2006, 11:27 PM   #7
lilpup69chevy
67-72 parts finder
damn without knowing i would just say guess it i know you'll use one big post one little one try it both ways either way its not gonna shock you
Old 09-01-2006, 11:41 PM   #8
truckdude239
truckdude239's Avatar
its also possible your battery cable has came apart inside and your not getting power to the starter the rest of the truck gets power of the other wire of the terimal that run to the juntion box on the fender right above the battery
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-02-2006, 04:00 AM   #9
screamin_eagle
screamin_eagle's Avatar
given you have it in park and its a good starter. I'd say you should check for resistance
screamin_eagle is offline   Reply With Quote
Old 09-02-2006, 07:55 AM   #10
Solver
Solver's Avatar
If it is an auto be sure and check the neutral saftey switch
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 09-02-2006, 07:56 AM   #11
beautimus
beautimus's Avatar
If the truck is an automatic with column shift, i would say check the neutral safety switch, maybe hold up on the shift lever and try to start. but since its a 4x4 , i would asume its a stick shift, so that probably aint gonna help.
Have you had any indication of problems before now? maybe the starter not acting right before? if so i would suspect the solenoid, or the small wire going to it. i have had that wire burn in two inside the insulation, i couldnt tell untill i pulled on the wire and the isulation just pulled in two. thats where i would start. check that wire from end to end for continuity and if it shows good i would replace the solenoid. if that dont fix it then i would be stuck and have to ask somebody else. good luck, Tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 09-02-2006, 01:27 PM   #12
deer slayer
everyone thanks for your help i got the starter was froze up thanks again
jeff
