Old 09-02-2006, 10:42 AM   #1
MNorby
MNorby's Avatar
Gen 2 blazer tank in gen 1?
Has anyone put a 30+ gal tank out of a 73-91 blazer into a gen 1? Also anyone have a pic of the factory mounts for the stock tank. All my parts are missing.
MNorby is offline   Reply With Quote
Old 09-02-2006, 12:39 PM   #2
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: Gen 2 blazer tank in gen 1?
I thin it has been done, but the tank may hang too low under the frame, but under a 4x4 it should be fine, just make sure you get a tank from a carburated blazer/suburban (suburban tank will fit too)
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 09-02-2006, 12:56 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
Apparently that is what I have. It in the K5 when I bought it. I dropped the tank to clean it out and it fits in there pretty good. I added some thick rubber strips on top where it hits the frame. That is probably the only place to really worry about. I will attach some pics as soon as I get a chance.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-02-2006, 02:10 PM   #4
MNorby
MNorby's Avatar
Some pics would rock. Apparently the PO removed tank and crossmembers that atttached it
Old 09-02-2006, 07:25 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Crossmembers?
Owner/Op: "TN Classic Transport Carriers"
Daily Driver: "HerNameIsRio" 68 GMC SWB
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Toy Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-02-2006, 10:13 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
The PO did this. Looks like a 30 gallon, the float and pickup assembly has 5 ports. 1 big to the filler, 1 to the filler vent, 1 going to the engine, 2 plugged up. The guys at the parts counter said this is what came in a mid 80's Suburban and Blazer. Anyway, the picture isn't great, but I am away form home and it is the only view that is already on my laptop. I can take a few more in a couple of days. Its hangs down some, but doesn't look like a big concern for moderate wheeling. I guess someone that is serious about rocks might have a problem with it. Damn the 'ol Critter looks pretty ratty from the back! needs a pipe bumber!
Old 09-03-2006, 03:43 AM   #7
MNorby
MNorby's Avatar
Cool, thanks. Yeah there is that rear crossmember htat looks like your tank strap bolt to but nothin up front to attach stars too it looks, I'll have to look closer tomarrow
Old 09-03-2006, 09:58 AM   #8
vtblazer
vtblazer's Avatar
I've heard it's a popular mod to get the 87 & up tank when going TBI or TPI due to the fuel pump already being in the tank.
This thread is good timing, I'm thinking about one for my TPI swap but concerned about how low it will hang for wheeling.
Keep us posted on your findings.
vtblazer is offline   Reply With Quote
Old 09-03-2006, 12:10 PM   #9
Critter
Future TOTM Winner
Critter's Avatar
there is a crossmember that is forward of the tank that the straps are attached to, and then of course the bolts in the back that you tighten to hold everything in place. I am assuming that this crossmember is original, but it could be that it was added or at least moved to make the tank fit. I'll study it a little more when I get a chance to look in person.
As far as the '87 and up tank that VTBlazer is talking about, I believe the only difference between that and mine is the sending unit. Tank should be the same.
Old 09-03-2006, 02:53 PM   #10
onetonk5
Cereal Killer
onetonk5's Avatar
just raise the floor a little
onetonk5 is offline   Reply With Quote
Old 09-03-2006, 11:08 PM   #11
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
my buddy has the tbi 30+ tank and it is an easy swap but even with all of the 6"+ lift and tires he has, he has still managed to pound the bottom in a little.
trkklr77 is offline   Reply With Quote
Old 09-04-2006, 01:06 AM   #12
MNorby
MNorby's Avatar
does the tp[ pf the tank just ride on the bottom of the truck floor?
Old 09-04-2006, 04:28 PM   #13
trkklr77
trkklr77's Avatar
no, the straps go all the way around.
Old 09-04-2006, 11:45 PM   #14
MNorby
MNorby's Avatar
wow i butchered the spelling on my last post. Anyways this is what the bottom looks like currently...
Old 09-08-2006, 10:53 PM   #15
MNorby
MNorby's Avatar
Can anyone tell me if I am missing parts for a stock location fuel tank?
