Old 09-03-2006, 08:12 AM   #1
jaros44sr
jaros44sr's Avatar
4x4 Alum. Flexplate Cover
Just bought one, but there aren't enough holes in my trans. to bolt it up, what gives? Didn't have one on it when I bought it, so I bought a pc. that was sheet metal, that one only has 4 holes in it and it fits. The alum. one has 6 holes, do I have the wrong trans. in my Jimmy? thanks for any help. Jim
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-03-2006, 08:22 AM   #2
meathead95
computer illiterate
meathead95's Avatar
Re: 4x4 Alum. Flexplate Cover
the aluminum one is for a 700r4
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 09-03-2006, 09:53 AM   #3
vtblazer
vtblazer's Avatar
The aluminum one is for a 'K' series case and are used in conjunction with torsion rods that tie into the motor mounts.
vtblazer is offline   Reply With Quote
Old 09-03-2006, 08:03 PM   #4
jaros44sr
jaros44sr's Avatar
Thanks for the info., so are you saying someone switched out my trans. and put a nonstock unit in?
SAFETY FIRST
AS usual, off topic
Jim
Old 09-04-2006, 06:57 AM   #5
vtblazer
vtblazer's Avatar
No, not saying that, just a later model aluminum cover.
Old 09-04-2006, 08:50 AM   #6
jaros44sr
jaros44sr's Avatar
Does it tie into the tower or a bolt on the motor mount? Thanks I thought they were all the same, my mistake. Thanks for your time Kurt
SAFETY FIRST
AS usual, off topic
Jim
Old 09-04-2006, 12:43 PM   #7
vtblazer
vtblazer's Avatar
If it's like my cover is, there are two spots on the bottom of the aluminum cover that will accept the bolts that tie the rods coming from the motor mount itself IIRC.
No worries, it's all good.
Old 09-04-2006, 06:17 PM   #8
jaros44sr
jaros44sr's Avatar
[QUOTE=vtblazer;motor mount itself IIRC.
No worries, it's all good. [/QUOTE]
So what's a 2 r c? Really Curious?
SAFETY FIRST
AS usual, off topic
Jim
Old 09-04-2006, 06:33 PM   #9
vtblazer
vtblazer's Avatar
those are eye's...
I = If
I = I
R = Remeber
C = Correctly
Old 09-04-2006, 07:28 PM   #10
jaros44sr
jaros44sr's Avatar
those are eye's...
I = If
I = I
R = Remeber
C = Correctly
Man I have a long way to go on this computer!!! LMAO
SAFETY FIRST
AS usual, off topic
Jim
Old 09-05-2006, 06:11 AM   #11
vtblazer
vtblazer's Avatar
Like I said...
