Old 09-04-2006, 04:06 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Stuck Thermostat?
When I've parked the truck after driving it the past 2 days, I've noticed that i've been dropping some coolant overflow. The temperature's been in the low 90's which is to say average for around here and I haven't added any coolant in months. Once it cools down I'll check the radiator to see how much has been dropped but what do you guys think? Normal or possible stuck thermostat?
Oh yeah, my temp gauge doesn't really work either.
Ole Blue 68 is offline   Reply With Quote
Old 09-04-2006, 04:08 PM   #2
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: Stuck Thermostat?
take the thermostat out and take something like a torch or maybe a lighter even or something to heat it with hold it with some pliers and see if it opens shouldn't take more than a minute or two that will tell you if its stuck
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 09-04-2006, 04:45 PM   #3
67chevy2wd
67chevy2wd's Avatar
Heat some water up to the temp it is supposed to open up at and drop it in and see what it does, if it doesn't open all the way up it is shot. I would say don't use a torch or direct flame, just because it opens with a torch doesn't mean it will open with hot water.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 09-04-2006, 05:21 PM   #4
cdowns
cdowns's Avatar
lots of people just dont take the time to fill the radiator correctly filled cold it'll leak out like that
Old 09-04-2006, 05:33 PM   #5
Greaser
Greaser's Avatar
A pan of water on the stove works great
Greaser is offline   Reply With Quote
Old 09-04-2006, 09:55 PM   #6
Ole Blue 68
Thansk for the advice all, I'll give the hot water a try.
cdowns, I haven't topped off the coolant in a couple of months so I'm not sure why it would start overflowing now all of a sudden.
Old 09-05-2006, 12:19 AM   #7
tom71
what happened to flint mi
tom71's Avatar
before you pull the t stat you could pull the radiator cap, clamp off the heater hoses and let it run till it gets hot. the water in the radiator should appear to be to be moving if your t stat is good as well as your upper and lower hoses should be hot , your radiator could be plugged as well .
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
