Old 08-12-2006, 02:08 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
carrier bearing
Well, I think I blew my carrier bearing out last night. I felt a driveline vibration as I was cruising home. I have a 2-piece driveshaft in my SWB, probably from the PO putting in a man. tranny. I looked up under the truck and the housing of the carrier bearing has come out the rear of the x-member. I don't even know if this is a stock type carrier bearing. The first pic is a view from the side. The second pic is a side view from the bottom showing how the carrier actually came out through the back and the mount is twisted 90* to the right. What do I need to do to fix this? I haven't fully lifted the truck up and gotten under to do a complete inspection yet. It's so hot here I'm gonna wait till later this afternoon.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-12-2006, 02:12 PM   #2
chevymad
Re: carrier bearing
The spot welds broke. I've done that to a couple, finally figured out to weld the new one up before I put it on. Those tiny spots are ridiculous.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 08-12-2006, 03:02 PM   #3
67Fleet
67Fleet's Avatar
Re: carrier bearing
So what do I have to do to fix it? Is it something I can do without removing everything? I have a welder.
-Bret
Old 08-12-2006, 04:23 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
Re: carrier bearing
I've broken 3 of these and every time I've done it I had to remove the driveline. If yours is like mine, you'll have to have the carrier pressed out and a new one pressed in. It sucks when it breaks. Yours looks like it has the two bolts that hold it in from the top, which is what mine had. Not sure if you can weld it back together with any sort of reliability. Someone else may be able chime in with other info.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 08-12-2006, 04:34 PM   #5
incoma
incoma's Avatar
Re: carrier bearing
You'll have to pull the driveshaft, but you can re-weld the top of the carrier bearing housing back on. I had a guy at work use a MIG welder to fix mine about 3 weeks ago. Solid as a rock now.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 08-12-2006, 08:35 PM   #6
67Fleet
67Fleet's Avatar
Re: carrier bearing
Well, I welded it back together. Didn't need to pull the driveshaft. The bearing was still good, so I got lucky. I was able to spin the housing down enough to get to it with the MIG. It was originally only spot welded in like 8 places. I welded it up good, hopefully no problems from here. Thanks for the input guys.
-Bret
-Bret
Old 08-12-2006, 10:46 PM   #7
Green Machine
Green Machine's Avatar
Re: carrier bearing
The ones I have been getting from NAPA here are already welded along the sides in addition to the top spot welds,
something to consider when you need a new one.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-13-2006, 02:44 PM   #8
chevymad
Re: carrier bearing
That's good to know Napa's changed.. my last 3 were napa and they were spotted just like this guys.
Old 08-13-2006, 09:59 PM   #9
TP from Cntl PA
TP from Cntl PA's Avatar
Re: carrier bearing
Guys, if you think that is bad...........I am so sick of GM's carrier bearings it is unreal........My Cummins truck eats them as fast as I can put them in. I am going to remove everything from the bellhousing back(All GM) because none of it is holding up. The original carrier lasted longer than the new ones!
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 09-02-2006, 04:21 AM   #10
screamin_eagle
screamin_eagle's Avatar
Re: carrier bearing
wow that sucks I just put one in today. Hope it holds up
screamin_eagle is offline   Reply With Quote
Old 09-05-2006, 07:04 PM   #11
farside847
farside847's Avatar
Re: carrier bearing
Mine from napa just blew out too. It was welded up all the way but it sheared off where the metal starts to go around the bearing. I think Im going with a one piece shaft to get rid of it this time....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 09-05-2006, 10:23 PM   #12
Sammy
Re: carrier bearing
I wonder if they are having these made somewhere that the manufacturer is using a cheaper or smaller guage metal? If you don't have a out of balance condition from a bad U-joint those carriers should last a # of years.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-05-2006, 10:50 PM   #13
71SWBChevy
71SWBChevy's Avatar
Re: carrier bearing
Hey this is a kindof related question, can you easily use the one piece shaft from a 6 cyl. truck in a V-8 truck with no problems?
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 09-06-2006, 09:43 AM   #14
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: carrier bearing
Throw it all away and have a1 piece made. Its a good fix on a Short bed truck and can also be done on a long bed. I have both and they work perfect. I forgot what a carrier bearing looked like.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-06-2006, 01:06 PM   #15
steveo10
steveo10's Avatar
Re: carrier bearing
just found out today that mine is broke. i ordered a new one and should be here in the morning. i hope they don't keep blowing out.
steveo10 is offline   Reply With Quote
Old 09-06-2006, 04:09 PM   #16
neonlarry
neonlarry's Avatar
Re: carrier bearing
I got tired of replacing carrier bearing and got one of these. One thing to check is to make sure your rear end is centered If its not that will eat up carrier bearings as fast as too great a pinion angle will eat U-Joints.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-06-2006, 10:59 PM   #17
steveo10
steveo10's Avatar
Re: carrier bearing
hey larry did you make that or buy it? looks bulletproof i like it.
Old 09-07-2006, 07:17 AM   #18
neonlarry
neonlarry's Avatar
Re: carrier bearing
I bought it from here: http://www.iedls.com/bearings.html
Old 09-07-2006, 07:28 AM   #19
Joe67
67 is sold
Re: carrier bearing
For a few hundred bucks you can have a nice custom driveshaft made that will solve your problem as well
Maybe the GM carrier bearings aren't designed to handle what that cummins is putting out...
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-07-2006, 07:42 AM   #20
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Re: carrier bearing
I was having problems with my u-joints and carrier bearing. It actually cost me less to have a custom 1 piece drive shaft made and put in with new u-joints than it would've cost to replace the 3 u-joints and carrier bearing.
Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
