Old 09-06-2006, 02:21 PM   #1
jasonrmorrow
Easystreet dual needle gauges
Anyone have any experience with these, i just got my single needle in for my tank, and it has a separate fitting as oppose to the VIAIR which has the mounting studs as the fitting.
anyone know what the backside of a dual needle easystreet looks like ??
Thanks.
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 09-06-2006, 03:14 PM   #2
jimmydean
jimmydean's Avatar
Re: Easystreet dual needle gauges
I ordered the gauges that Porterbuilt pointed out because they were cheaper than the easy street ones and I don't think he would use junk.
jimmydean is offline   Reply With Quote
Old 09-06-2006, 05:52 PM   #3
jasonrmorrow
I called easy street and they say the mounting studs are separate from the fittings, i can get them through work, about 10 bucks more per gauge than the viairs, but its worth it, i can at least service the friggin system this way.
The easystreets are still a threaded fitting, so i'll use my union and then line fitting, no problem. It came with a little push on fitting for the lines, dont trust that to 200 psi !!
On airbags
