TROUBLESHOOTING? Heater Fan Keeps Running And Doesn't Respond To Fan Switch
I just installed a factory A/C setup in my 72 Blazer and got everything wired in. The problem I have is that when I turn on the ignition, the heater fan blows on high, and no matter where I place the fan switch, it continues to blow on high and I can't turn it off. Does anyone have any ideas on where I could begin to fix this problem? Thanks
My Heater Fan Will Not Stop Running Can You Help???
![]() Join Date: Apr 2004
Re: My Heater Fan Will Not Stop Running Can You Help???
I sounds like you have the hot wire going to the wrong place. The switch should step down the current. It doesn't sound like this is happening. Is the switch bypassed?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: Help! How can I get my heater fan to stop running????
Is the control new or used, it could be shorted, if not check all the wires again.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
Was it all new stuff?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Everything is used, but appears to be newer. I'm thinking it's probably the control, but wanted to get some other opinions before I start replacing parts
Everything is wired correctly. Could the control be bad?
Designated A-hole!
I would get a multimeter and start checking wires before I bought new parts.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
ac
High speed blower relay is getting power all the time . If it is wired right then your fan switch is shorted inside. Unplug connector to fan switch-if fan does not run switch is bad-(or wired wrong).
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer Last edited by jhow66; 09-07-2006 at 02:18 PM. |
Yes. When you put the fan control on high speed it trips the relay mounted on the heater box ( up behind glovebox on right end). Make sure the relay is mounted tight as the ground wire for relay goes under one of the screws.
I actually ended up grounding it to the body. I know it has a good ground, but the fan is still blowing on high.
#15 |
Ok then unhook the fan switch. If blower does not run then your switch has to be the problem. Most likely you will find that the switch has been getting hot (melted plastic from loose connection). This causes the parts inside the switch to fail (springs, tabs, etc. loose their tension from the heat). The other two speeds on the switch are controled by a resistor on the back side of heater box. Do they work?
#16 |
I bought a used AC wiring harness when I did my non-AC to AC conversion. The plug for the fan speed switch was melted. I never even bothered to hook it up. I bought a new connector and a new switch.
Further I didn't bother to use the 30+ year old relay for high speed. I wired in my own relay and mounted it to the same screw. I have a 10 gauge wire with its own fuse coming off the battery supplying a clean 12+ volts to the business end of the high-speed fan relay. The only draw back is if I leave my set-up in the high speed fan position then try to turn off the truck. The HEI I installed gets a nice, clean 12 volts out of this circuit and keeps the truck running. When I really get ahead of the game I'm going to install an extra fuse block to run all the things GM should have installed for me. To make a long story short I'd look at that switch and connector. GM ran a lot of amps through that thing. After 30+ years and lots of furry connections you're going to get a lot of heat back there. To prevent future melt-downs put in a new relay and run a seperate circuit. You'll never melt that connector again. I have my headlight relay upgrade and hi-speed fan relay upgrade all running the same relay. I only need to keep one spare in the glove box.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#17 | |
You are correct about the melted plastic. The old harness was melted at the control connection. As far as the other 2 speeds, I can't tell because it only blows on high. |
#18 |
So, I guess I need to replace the relay and control switch???
#19 |
Do you have a DMM? you could test these before you waste any money on something you don't need. If not, buy away, it should be too much $$.
#20 |
Just try the switch first. Did you check it?
#21 |
#22 | |
#23 | |
However I wouldn't go buying parts yet if I was you. IIRC, the voltage coming out of the switch is changed to give you different fan speeds. It has been a while since I got mine working but the fan speeds were something like 3 volts, 6 volts, then 12 volts. You really need a Digital Multi Meter (DMM) to figure out your problem. If I was shotgunning this thing, since your fan works on high no matter what position the switch is in, until you unplug the relay, I'd replace the plastic connector behind the switch and the switch itself. Think about it. For a relay to work you need a voltage to get to the relay. This then closes the connection in the relay which then sends power to the fan through a different, beefier circuit. It sounds like the lower voltage wires are all shorted together and turning on your relay. If your plug is all melted this is a very strong possibility.
#24 | |
#25 |
I replaced the relay because it was only $10. It now has a clicking sound under the hood when I have it on A/C and move the fan switch through the positions. I still have no difference in fan speeds though. Only high regardless of the position of the control.
