Old 09-07-2006, 10:32 PM   #1
76bonanza
76bonanza's Avatar
carb removal
I am installing a carb space. I am thinking remove all vaccum lines fuel line throttle rod remove carb. Clean then put on new gasket spacer gasket carb. What is the torque on the studd bolts? Should I use anything on the gaskets? anything else I should do when the carb is off?
Any other thoughts on the subject?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-07-2006, 10:53 PM   #2
jhow66
jhow66's Avatar
Re: carb removal
If you have never done this before, take a number of photos before you start. Gaskets go on dry.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-07-2006, 10:59 PM   #3
msgross
msgross's Avatar
Re: carb removal
Holley says 60-80 in/lbs and do it in a cross pattern, like rims. If your vacuum lines are getting hard and brittle then you may change them. PCV too...
msgross is offline   Reply With Quote
Old 09-08-2006, 07:55 AM   #4
76bonanza
76bonanza's Avatar
Re: carb removal
You mean take a pic of the throttle linkage and vac lines for reference?
1968 c10
lowered 3" 4"
Old 09-08-2006, 10:12 AM   #5
jhow66
jhow66's Avatar
Re: carb removal
Right
Old 09-08-2006, 10:48 PM   #6
alf1096
alf1096's Avatar
Re: carb removal
When its all said and done if you have extra parts you know its done right
1970 Short Stepside----Process of Restoring
1983 1/2 Silverado
alf1096 is offline   Reply With Quote
Old 09-08-2006, 11:18 PM   #7
OhioDan
OhioDan's Avatar
Talking Re: carb removal
Tighten your carb down a little at a time. You don't want to crank one down to prescribed torque and then move on to the next one. ( good way to break an ear off of the carb?) My $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
