Old 09-09-2006, 07:26 AM   #1
dwaite72lnghrn
Re: Front dress for a BBC conversion? Make a ZZ502 look "OEM"?
I have since converted to serp setup. I went with the factory setup because it came with all of the acc. which are new or remanf parts. The only problem I have is it is real close to the rad so the OEM shroud will not work. I am running 2 fan in front a 14" and a 10". I am hammering out a new shroud to fit just have to git r dun.
I added the serp pictures. I figured it wasn't factory so I left it black. The serp setup came with the 105amp alt, new power steering pump AC comp, and water pump. I could have gone Scrap yard but then I have ??? age and condition on a new engine. Figure where to put the electric fuel pump and Change the trans mount when you do it or the first month it will be gone along with the carrier bearing. I went with the HT502 because I tow with the truck and the best range to run is 2400-3200rpm(45mph-68mph) with the 4.10 and 30" tires. The ZZ502 is going to want to run at about 3600-5000rpm. So Stall is in order for it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
Last edited by dwaite72lnghrn; 09-09-2006 at 07:46 AM. Reason: additions picts. and words
dwaite72lnghrn is offline   Reply With Quote
