someday
![]() Join Date: Dec 2001
i want to conver my blazer to 2x?????
I was wondering what my options are to convert my blazer to 2 wheel drive. I would like to go with bags and a stock trailing arm setup but i'm not sure if it can be done. Thoughts and sugestions are appreciated.
jason
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
the two wheel that i have i made from a 4x4 and wanted to do the same thing in the rear but the frame on a 2wd bows out when it get's to the coil sping crossmember if you used bag's and changed the angle of the trailing arm's to match the 4x4 frame you could do but you cant bolt in the factory set up and go. I just took a few of the 4x4 leaves out and got just a little rake but the were allready saging.
hey i've done this to my 69 blazer and if you will pm me then i can give you exact specs on everything i used
