09-13-2006, 09:28 AM | #1 |
Manual Window wont'r roll down
hey guys, well I finally found the tool to take off the window lift handle. I was hoping that It just needed a good lube, but I think it is shot. It seems that the bearing right behind the window handle is going out. I sprayed some WD on it and it helped a bit. Have you guys had any experience with this. Can you take that bearing out and replace it or do you have to put in a new regulator? Is it even a bearing or just a sleeve? Anyway to fix it without taking it out of the door? Any thoughts would be greatly appreciated.
Thanks |
09-13-2006, 10:11 AM | #2 |
67-72 parts finder
Re: Manual Window wont'r roll down
i would think you could just replace the regulator to solve the problem as i know no way of fixing one that would be worth the time or effort
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
09-13-2006, 11:11 AM | #3 |
You would probably have to replace the regulator as a unit. I have never seen a regulator actually pulled apart, though, so I may be wrong.
