Old 09-13-2006, 11:06 AM   #1
abadsvt
abadsvt's Avatar
What to do with the heater core?
I am trying to figure out what to do with the heater core on the firewall. I believe that is what you call it. I plan on doing a LSx conversion and want heat and A/C but wanted to keep the firewall clean. Does anyone know of an aftermarket heater core that is small enough i could put it underneath the dash or anything else that might work? Pictures would be the best along with some info but i will take what i can get. Thanks Josh
abadsvt is offline   Reply With Quote
Old 09-13-2006, 11:23 AM   #2
69CvyPickup4x
69CvyPickup4x's Avatar
Re: What to do with the heater core?
www.vintageair.com
69CvyPickup4x is offline   Reply With Quote
Old 09-13-2006, 11:29 AM   #3
shifty
Questionable
shifty's Avatar
If you are looking for a "junkyard" option, you may consider retrofitting the heater core and blower motor from a late 1980's model Chevy S10 or GMC S15.
I've had my LS1 bolted up for a while now (but not wired or plumbed for fuel/cooling) and just deleted my entire heat/AC assembly. I think I'm going to to do Vintage Air eventually and reuse my compressor. Not sure yet. My main snag has been with figuring out the stupid hydraulic clutch right now and bolting up the tank, which has left me completely disinterested in the project.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-13-2006, 11:39 AM   #4
abadsvt
abadsvt's Avatar
So you are saying that i should contact Vintage Air or is there a specific model part that i should get? Thanks Josh
Old 09-13-2006, 12:42 PM   #5
Deuce
Deuce's Avatar
This is my $100 solution to cleaning up the firewall.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-13-2006, 03:39 PM   #6
boogie67
boogie67's Avatar
I used a forklift heater it was small enough to fit behind the glovebox door.I used copper tubing to run the lines out the vent. The hoses will run inside the fender and come out on the front part of the fender.I dont have much glove box left but I can live with that,
77 swb starting all over again.
boogie67 is offline   Reply With Quote
