09-12-2006, 08:45 PM | #1 |
Where's my beer?
Replacing fuel pump in a V-6?
As the title says, is it the same changing the fuel pump in my V-6 as in a small block?
Paul How do you make the invisible, visible?.........You take it away. |
09-12-2006, 09:02 PM | #2 | |
Re: Replacing fuel pump in a V-6?
Can't help with the fuel pump, haven't had an issue with mine(YET).
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
09-12-2006, 09:33 PM | #3 |
Where's my beer?
Yeah, went to start it the other morning to go to work and nothing, got rained on enough so I took the minivan instead fuel pump was acting up for a while but was hoping it'd last longer.
Thankfully I didn't sell it when I posted it for sale, I've used enough to not let it go now! Anybody?
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 09-12-2006 at 09:33 PM. |
09-12-2006, 09:51 PM | #4 |
Aluminum slot wheels rule...
Just pull the bolts out, take out the old one, and bolt the new one in. It's as simple as simple can get.
09-13-2006, 04:32 AM | #5 |
It's actually easier to do the fuel pump on a GMC V-6 than a small block Chevy. It's mounted higher, and you don't have that push rod to deal with.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-13-2006, 09:50 AM | #6 |
I thought they had a tang on them...............
09-13-2006, 03:08 PM | #7 |
Yes, a long lever that rides on an eccentric on the front of the cam sprocket.
09-13-2006, 07:00 PM | #8 |
Where's my beer?
Thanks Jake and Bob, I looked closer at the truck after work and the pump is indeed mounted higher, it should be a snap replacing.
09-13-2006, 08:52 PM | #9 |
Stubby wrenches may help you out when unbolting it. Just a thought.
09-13-2006, 09:01 PM | #10 |
Where's my beer?
Thanks.
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 09-13-2006 at 09:02 PM. |
