09-16-2006, 09:58 PM | #1 |
rocker studs pulling out !!!!ARRRGH!!!!!
well i have adjusted the rockers twice on the 69 c20 350 ci and they keep getting loose....
the nuts are good....they are the press in type, rocker studs. i have a set of 882 heads w/screw in rocker studs in the garage.. guess i will be pulling the heads...should i just pull the engine..? i know my back would like it much better.. does this sh!t ever end... |
09-16-2006, 10:16 PM | #2 |
its all about the +6 inches
Re: rocker studs pulling out !!!!ARRRGH!!!!!
if you pull it, you can detail the engine and underhood... and I know what a sucker you are for makin it perdy
09-16-2006, 10:24 PM | #3 |
press in studs are crap.
68 short step, 406/700r4, 9" w/discs. |
09-16-2006, 10:37 PM | #4 |
You can pull the studs with the heads and engine in the truck, tap the holes and put in the screw in stud with locktite. Remember to drain the radiator. It can be done, I think total time would be less than pulling the engine.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 09-16-2006 at 10:38 PM. |
09-16-2006, 11:02 PM | #5 | |
Are you SURE that the studs are pulling out? It happens, but I've only seen it a couple of times. |
09-16-2006, 11:23 PM | #6 |
You could pin the studs for a great deal less time and money BUT... I would definitely pull the heads to avoid any metal shavings , debris etc... getting into the engine. Bill is right on when saying to pull the heads. the time you save working at a convenient height on a workbench will be well worth the time invested to pull them off the engine. JMHO, Dean
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin |
09-16-2006, 11:31 PM | #7 |
Yeah I had this happen to me. I just left them on the motor pulled the problem stud and threaded the hole and replaced with a screw in stud. Put some grease around the area and wipe out when done. Motor ran for along time after that NO problems.
09-16-2006, 11:41 PM | #8 |
