Old 09-14-2006, 01:57 PM   #1
dalbers
dalbers's Avatar
c-notch
Are the bolt in c notches any good? I put the rear flip kit from djm on my 05 silverado and need to notch the frame. I figured this is the best place to find out. Thanks
dalbers is offline   Reply With Quote
Old 09-14-2006, 02:20 PM   #2
jimmydean
jimmydean's Avatar
Re: c-notch
I bought the bolt in kit, but I will weld it in place. I like the extra coverage the bolt in version gives you, but I don't trust that it won't develop play and cause a weak point later on.
jimmydean is offline   Reply With Quote
Old 09-14-2006, 10:27 PM   #3
powell72
powell72's Avatar
Re: c-notch
We put a bolt in notch in my buddy's '98 extended cab after we did a 5/7 and he never had any issues.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-15-2006, 01:27 AM   #4
dalbers
dalbers's Avatar
Re: c-notch
thanks guys
Old 09-15-2006, 01:52 AM   #5
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: c-notch
i agree with jimmydean i'd bolt it AND weld it if it was on my truck just for the extra security
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 09-15-2006, 07:41 AM   #6
Rokcrln
Rokcrln's Avatar
Re: c-notch
I have done bolt in's with out a problem but I do like to add a few welds on them if possible. If you do not weld then bolt it in and drive to a muffler shop and have them put down a few welds for you. They should not charge much and if you show up around quitting time with a 12pac they may not charge at all!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-15-2006, 02:22 PM   #7
jimmydean
jimmydean's Avatar
Re: c-notch
I thought I recalled a pic from Kevin with a welded "bolt-in" notch. I could be wrong, but I got the idea from somewhere.
Old 09-15-2006, 11:28 PM   #8
SCOTI
SCOTI's Avatar
Re: c-notch
Kevin
LFD Inc.
That's what I did on mine as well. I bolted it in then drove up to work & welded it. I also bought the guy that did the work some beers..... .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2006, 11:43 AM   #9
AirMale
AirMale's Avatar
Re: c-notch
I welded in a bolt on c notch
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 09-16-2006, 06:59 PM   #10
SCOTI
SCOTI's Avatar
Re: c-notch
It would be stronger than the original frame section using this method.
That's what I did on my 68. I bolted it in while using it as a driver & then welded it like this once I began using it to pull my 18ft car hauler. I will admit, my welds don't look as good as these since I did it outside & the wind was killing me that day.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2006, 06:33 PM   #11
BowTieOgre
Re: c-notch
Ah beer, the universal currency! I've gotten several hundred $$ of work done with $30 worth of beer.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
