08-27-2006, 10:03 PM | #1 |
350+dual flows= fun :)
my 75 frame off..
whats up?!...
im still in the process of restoring my 69 camaro, as well as my 84 z28, 69 corvette motor.. and heres my old truck that tryd to kill me on the 405... wheel bearing went out on my at around 12:30 pm on the 405..i was doing about 75 mph...spun out about 3 times from the fast lane to the slow lane....somehow i didnt hit anybody.. heres what my 69 camaro looks like as of today.. and the reason im here, and my next project...here it is....i paid 500 bucks for this as is, no motor......i pulled the 350 4 bolt out of my white truck before i junked it, and set it in my new shortbed... my plans for my 75 shortbed... 1) frame off 2) slam 3) one piece back window 4) 454/400 trans i need to know what i need to slam my truck......4 front 6 rear?... anybody know what componants ill need?....do i need lowering springs? or just spindles? this s*it is confusing! |
08-27-2006, 10:15 PM | #2 |
Designated A-hole!
Re: my 75 frame off..
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-27-2006, 10:27 PM | #3 |
yeller
Welcome to the board from MN.
Truck looks nice, will even look much nicer lowered. To acheive your 4/6 drop, you can use 3" drop spindles up front with 1" drop coil springs. In the rear, you can use a flip kit plus drop shackles or lowering blocks. Hope this helps some.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 08-27-2006 at 10:28 PM. |
08-27-2006, 10:28 PM | #4 |
In Progress
nice truck! id go with 2" springs, 3"spindles, axle flip with 2" shackles
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
08-27-2006, 11:59 PM | #5 |
Insert Witty Text Here
I have to add my usual line about spindles. The 3" drop spindles will probably not clear your wheels if you have 15" wheels unless you do some ginding on the caliper and/or the lower control arm (LCA).. Western Chassis has 2.5" spindles that clear my 15" Rally wheels with no problems.
Slonaker |
08-28-2006, 12:12 PM | #6 |
Nice projects I also have a 3rd gen camaro ,RS though HEHE. 4/6 drop rims and tires.should get you going.GL
FOR BEFORE AND AFTER PICS AND A PIC OF MY BIKE AND MY WIFE (YEA RITE) CLICK ON MY Photobucket |
08-28-2006, 01:36 PM | #7 |
thanx fellas.......i forgot to mention, i just want to use the 4x4 rallys....
08-28-2006, 07:25 PM | #8 | |
Happy to be here
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-28-2006 at 07:26 PM. |
08-28-2006, 10:07 PM | #9 | |
Street Rod Restoration
You need to look into a DJM suspension system. It will have everything you need.
Follow me on Instagram @ hot_rod_shop Last edited by N2TRUX; 08-28-2006 at 10:53 PM. Reason: Cleaned the post up. |
08-28-2006, 11:02 PM | #10 |
Junior Member
Chisholm Suspensions has a nice kit comes with everything.I got a 4-6 kit on my truck.Located in Santa Fe Springs Ca.
Scott C. 84 Custom Deluxe(under Construction) 87 Buick Grand National 91 Gmc Sierra daily driver |
08-28-2006, 11:42 PM | #11 | ||
hmmm, im not sure what style rim im talking about...its a truck rally wheel, with ring and cap....are those all the same back spacing? |
08-29-2006, 01:07 AM | #12 |
Junior Member
[QUOTE=75shortysocal;1792652]thats what im talkin about!....got a link? or pix of your truck stance?
I couldn't find a link tried www.chisholm1.com,but it wouldn't open.Here is their phone #562-946-3183 my kit came with re-arched rear leafs and shackles(not a flip kit)upper and lower tubular control arms,front springs and front and rear shocks.Here is a pic of my trucks stance,hope this helps and good luck.
08-29-2006, 09:58 AM | #13 | |
[QUOTE=84Custom;1792714]
08-29-2006, 02:05 PM | #14 |
Until Seventy Times Seven
You can achieve a 4-6 drop like 84Custom has or you can go a more popular route like some of the guys have mentioned:
In front, if you plan on retaining your 15" wheel, you may want to go with a 2 1/2" drop spindle. This will avoid any clearance problems between the 15" wheel and the LCA like Slonaker mentioned. Going with a drop spindle also maintains the geometry of the front suspension. Then, add 1 1/2" drop coils. Western Chassis offers both items. When ordering drop spindles, you'll need to know whether or not you have heavy duty brakes by measuring the thickness of the brake rotor. Your brake rotors will measure out at either 1" or 1 1/4" where 1 1/4" is the heavy duty brake system. In the rear, a flip kit which flips the axle from under the leaf spring to above the lift spring pack would give you a ~5" drop. The flip kit includes brackets that also realigns the pinion angle and maintains the proper drive shaft spacing after the drop. Shock extenders may be included to extend the lowered shock length and retain the some shock angle. Installing the flip kit is relatively simple, aside from having to remove snubber mount (rivets). To drop the rear even lower, using drop shackles like Jeff and 74gmc suggests are common. However, installing the drop shackle may involve notching the rear sill bracket of the bed floor for clearance. To avoid this clearance issue, lowering blocks may be used instead to avoid any clearance issues. Lowering block kits come with the lowering block in various drop ranges (1", 2", ...) and longer U-bolts. DJM offers the flip kip, drop shackles and/or lowering block kits. In the end, you will want to maintain, at least 3" clearance between the axle tube and the frame rail. Otherwise, you may need to notch the frame rail and install a C-notch kit. To determine the axle tube -to- frame rail clearance prior to your drop:
On a drop of 4/6 (or 5/7), check the backspacing of the wheels you plan on running to avoid any rubbing on the fender wells. Also, expect some LCA damage unless you drive cautiously on rough roads, over speed bumps, entrances, ... Belltech, DJM and Western Chassis all make lowering components for these trucks. You can visit truckshop.com, stylinconcepts.com, sporttruckdirect.com, performancesuspension.com, macssprings.com to name a few to order the items you need. Good luck on your build-up (er, down).
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 08-29-2006 at 02:24 PM. |
08-29-2006, 09:18 PM | #15 |
Junior Member
[/QUOTE]thanx!.......yea, i live real close to Santa fe springs...do you ever bottom out or scrape the lower arms in the front?...and are those wheels and tires on the truck bigger then the rally's?[/QUOTE]
I've never had it bottom out or scrape in the front.The tires are P275/60 R15,and the wheels are 15x7's all around.
08-29-2006, 09:23 PM | #16 |
-Chris
Welcome to the board, nice rides man.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
09-17-2006, 08:00 AM | #17 |
thank you guys,
im going to go look at a 66 shortbed running for 400 bucks!! ill get some pix. |
09-19-2006, 11:26 AM | #18 |
wow , i'd cut my left nut off with a dull butterknife for that 69' body
1987 350 TBI lowered 5/7 |
