![]() Join Date: Feb 2000
Powerwashed the engine this weekend
Rented a power washer this weekend. Worth the money, but there is still some hand work that needs to be done. Looks like I might need to get the flywheel resurfaced while it is off. It is a little discolored.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Suburbans RULE!
Big blocks are so cool!!
I would definately get that flywheel surfaced......it is cheap insurance for good clutch engagement. I bet you can't wait for that 454 to be in there instead of the 307!! ![]()
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
Half a bubble off!
Hey Mark, that looks much better. I assume all that was coming from valve cover area, how does everything else look? What's the plan concerning the switch? Cya, LB.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
looks good,
some of the best money I've spent was for a pressure washer, Now once i bring it out to clean something, everything I can think of gets cleaned.
71 c-10 6cyl ![]() 68 Camaro (wifes) 65 dodge town wagon (wanna buy it?) 97 crew cab f350 psd |
If you are putting in a new clutch, don't even think about doing it without having the flywheel resurfaced, no matter what it "looks" like.
Tim |
How about the flip side. It's okay to use the old clutch, if it is in good shape with alot of life left, with a resurfaced flywheel, right?
I know it adds more to the budget, Mark, but the labor to replace the clutch pales in comparison to the price of a new clutch pressure plate. So even if your wallet (spouse!) cringes at the thought, surface the flywheel and get a rebuilt pressure plate and disc.
