09-20-2006, 01:38 AM | #1 |
Gas Tank Neck gasket
I need to replace the gasket around the gas tank neck, yes the tank is still in my cab, the last time this was done was when I did the rebuild and had the tank out of the cab. Is there a kind of easy way to replace this thing without removing the tank again?
Original owner '69 C20, long, fleet. 454 BB with Edelbrock stuff. Work truck for years, 2nd restoration going on. '69 C20 '03 Tahoe Z71 70 Hp Johnson pushing aluminum bass boat. All things in life are uncertain, so eat dessert first. |
09-20-2006, 01:40 AM | #2 |
Re: Gas Tank Neck gasket
soapy water, or silicone spray.........cut the old one off but use some kind of lube and go slow to install the new one
09-20-2006, 08:41 AM | #3 |
250 V-6 Club
Bartstoy, If you do this with out taking out your tank could you please take some pics cuse this is something I am wanting to do.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523 Never ask a stupid question unless you want a stupid answer . |
09-20-2006, 09:21 AM | #4 |
Very good question.....I have to do mine tonight also...
I heard NOT to use vasoline as a lube, as it is a petrolumn base product that will deteriorate the rubber,. |
09-21-2006, 07:02 AM | #5 |
ttt
09-21-2006, 07:09 AM | #6 |
ArmorAll works.
09-21-2006, 09:50 AM | #7 |
I understand, from commercials of course, that there are some "personal lubricants" on the market that are water based.
Hook'em |
09-21-2006, 03:32 PM | #8 |
Thanks to all for your responses, going try some Armorall, and if that is a problem then some silicone grease. Will try and get some pix.
09-21-2006, 03:42 PM | #9 |
Never understood the big deal on replacing these. I just cut the old one out, clean the neck, then I use a light film of "Vasoline" on the neck of the tank and on the opening of in the cab. Putting light pressure on the rubber as you turn onto the neck. Slips right on every time. I've never had any problems using Vasoline. I just wipe off any excess after it's on.
1997 GMC Sierra Ext 1965 Mustang |
09-22-2006, 07:18 AM | #10 |
I was told vasoline will shorten the life of the rubber.
09-22-2006, 07:24 AM | #11 |
67-72 Addict!
I've always used dish liquid and never had a problem.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-22-2006, 07:19 PM | #12 |
Here is an update. The old one was hard to take out. But after cutting it in a couple of spots I was able to pull it through from inside the cab. To my surprise the neck of the gas tank is not centered in the hole. The new gasket does not slip in with any lubricant that I have tried, including dish soap, armorall and or silicone oil. If I new how to add pictures to my post I could show you what I am talking about. Anybody else run into this problem. I don' think removing the tank would make it easier, but I am willing to try anything at this point.
09-22-2006, 07:26 PM | #13 |
If you can get to the bolts that hold the tank in you can loosen them off a little and move the tank nozzle where you need it. Mine wasn't dead center in the hole but with a little pressure and Armor All it popped in place.
09-22-2006, 09:40 PM | #14 |
Custer had a plan too.
There's a joke there somewhere. Almost too easy.
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ) 05 Subaru Outback for mileage |
09-22-2006, 10:32 PM | #15 |
my rubber leaks and don't fit very well and after only 4 months of use its cracking from the sun uv rays and i put it on dry
09-27-2006, 02:33 PM | #16 |
250 V-6 Club
TTT any update on the install?
09-27-2006, 07:31 PM | #17 |
First of all it's not a gasket as I have been calling it, it's a grommit. eh!
Ran into another problem, there are two grommits that are used on these trucks, one is a 67-69, the other a 69-72. My original purchase turns out to be a 67-69 and the outside diameter is not big enough to fill the gap. I think if the neck were dead center it might work, but barely. So I have ordered the grommit for the 69-72. To loosen the gas tank seems simple enough, but I don't wan't to do that until I have the right grommit. So stay tuned.
