axel gears?
i have a 4.10 rear 10 bolt stock rear. my truck is a 3/4 ton im tryin to figure out if its posi what do you think is it also its a 70 gmc 2wd
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
c mon i know some one can help me?
Fabricate till you "puke"
Unless you go aftermarket, 4.10 is about as good as it gets on the corporate rear diff. I think some of the guys were talking about 3.90 & possibly a 3.73 ratio available.....but expensive. You could look around for a dana 60 with a 3.54 ratio, & swap it in to get a better all around gear. as far as posi unit, try jacking up the rear, & turn 1 wheel.....if the other turns the same direction, its posi.....if it turns backward, then its open. Hope that helps ....crazy AL
Cantankerous Geezer
Crazy Al's right about limited options on improving your rear gears. Randy's Ring & Pinion www.ring-pinion.com makes a set of 3.90 gears, but your pockets will be empty
Fred There is no such thing as too much cam...just not enough engine. ![]() |
