Sorting out option codes on glovebox sticker?
HI,
I've been looking at these for awhile, both on trucks I've seen locally and when people post pics of their option sheets, and like everybody else I've noticed that sometimes the codes are just 3 digits (for example C42 = heater) and sometimes they are 5 or 6 digits (for example C42AC = heater or 1C42AC = heater). Anyway I've been trying to see if there was any pattern as to when the 3 digit vs 5 digit codes were used. Not too much luck so far, apart from seeing that it doesn't seem to be a Chevy vs GMC thing, and not a year-to-year thing either (I've seen 1972's with 3 digits and 1972's with 5 or 6 digits). So far the only thing I've turned up that might explain it is the assembly plant. To be specific, every Flint , Tareytown, Atlanta, and St. Louis truck I've seen had 5 or 6 digits, while every Fremont or Baltimore truck had 3. But I haven't seen all that many trucks overall, so I can't be sure if that's the real explanation or not. Anybody willing to look at their option sheets and post what plant their truck came from and what their option #'s look like so we can maybe figure this thing out? |
My truck is a: 1968
Built in: St. Louis Option's codes are: 6 digits It would be intresting to see what the results are: You might want to set this post up as a poll:
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
I've got an example that will throw your plant theory out the window:
1968. Vin: KE248ZXXXXXX Z= Freemont, CA and it has 6-digit codes. 1969. Vin: KE149ZXXXXXX Z= Freemont, CA and it has 3-digit codes. I've looked everywhere I can think of and there is no pattern. None of it makes sense. If that doesn't confuse you enough, my '72 c10 has both three and six digit codes. If you ever figure it out, I'd like to know, because I've given up looking.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
![]() Join Date: Aug 2001
What does ABS on the shocks mean? I found it = Absorbers
Used to have a truck
1968 Fremont ... 7 digits all the way down.
No truck :-( |
1969 Custom 30 wrecker
I would love to find a way to decode the 6 digit codes. Some of mine are very mysterious as they don't have a description next to them.
Both my 69 and 71 have these 6 digit codes.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Dang it -- another beautiful theory ruined by facts
Ohhhh man. This option stuff is a can of worms when it comes to what plant did what. I have studied this for many years for Janesville, Flint, and St. Louis plants.
Here is what I can sum up: All 3 plants up through 1969 used the 6 digit RPO codes, ie 1PV6AB etc etc. Janesville in 1970 switched to the 3 digit RPO codes, ie PV6. Meanwhile Flint and St. Louis kept on using the six digit RPO codes through 1971. Then for 1972 they still used the six digit RPO codes, but then last 2 suffix codes changed from Alpha to Numeric as in: "1A11AA TINTED GLASS" was changed to "1A1120 TINTED GLASS", ie "AA" is now "20". Anybody know what the last 2 suffix letters such as "AA" or "20" means?? or the first number "1" in the example above? The suffixes can/could be different plant to plant, year-to-year, but generally are the same. In 1972 the Freemont plant had some printed with all 6 digit codes, and then some with just all 3 digit RPO codes listed. Then ... sometimes, on the same sheet, you may get a mix of both 3 digit RPO codes and 6 digit RPO codes (ie plants that used the 3 digit RPO as standard). It looks like when you get a true "mix" of RPO codes, the buyer was adding some odd/special equipment. Haven't heard of anyone with the GM books on here able to decode the oddball RPO's. The regular RPO's are easy to decode with a list. Hope this helps! Yeah right! -Roger
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
same RPO code no matter if is 3 or 6 digit, just look in middle of the 6 digit codes for the actual equipment regular production code,
Wanna try these?
I've seen your option sheet posted before and can't make out heads or tails on the 9XX option codes. That is the weirdest build sheet I've ever seen.
I don't know who would have that kind of info to make sense of it. -Roger
Option/build codes are a lot like women---sometimes when you think it makes sense~~~WELL~~~~~. I've come to the conclusion that sometimes it's better to leave things a secret!
"If a man is all alone in the middle of the forest and makes a decision without the aide of a women, is he still automatically WRONG?" If you have to ask the question~~~~~!!!! WTF-over!!~~Huck |
My 72 came out of the Fremont plant and all of the listed options are three digits.
Racedvl, I hope at least a few extras have been added to that truck in the 30 odd years since it was manufactured.
1972 C-10 LWB, 400/350, 2WD 1972 C-20 Custom Camper, 350/350, 4WD (Converted) |
#15 |
14.1 @ 96MPH
Mine's a '70 GMC from Fremont and it's got 3-digit codes all the way too. IIRC, my buddy's '69 Chevy had 3-digits as well, but I don't know what plant...and it got totaled, anyway.
In fact...I think nearly every truck I've seen around here has the 3-digit codes.
Project1970 - LS1 Swap Complete! ![]() |
#16 |
The only ones that have been added have been by me.
#17 |
its all about the +6 inches
racedvl...bummer you didn't check the option for oil pressure huh?
#18 |
Fabricate till you "puke"
LMAO @ longhorn! I think that read oil gage on the glove box
#19 |
Am I the only one here with 7 digit option codes?
04625AC ....parchment/cloth interior. Ive got 13 more like that . They all start with "0" . Fremont 1968
No truck :-( |
