Mixing in the rear end
My mistake - while at parts counter, asked what rear gear lube to put in differential - he gave me one bottle - I asked if that was enough for a complete fill - he ran and grabbed another off the shelf. AFTER I put all of one and almost all the second in, I noticed he had given me one bottle of Mobile 80W-90 and one of 80W-140 - I never thought to check the two. All of the 140 went in and darned near all the 90.
Do I empty and start over or go with it for a while and then change out? On the positive side, I also found that after a few taps with a hammer to loosen, the plug came out nicely using the end of a short 3/8" extension (I didn't have any square drives). It's starting to look pretty so heres a quick pic too.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
![]() Join Date: Jul 2004
Re: Mixing in the rear end
I don't think that is going to hurt anything, just a little thicker than you wanted - like a 80w-110. It might be a little stiff if you drive in cold weather. here in Iowa I like to run synthetic in the rear diffs, gets pretty cold here-guess I would run it for a while and change to synthetic, no big hurry. If the previous oil had been in there a long time this will clean it up before the next change. If you complain, the might give you some free lube for the next change ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
just needed to hear the same thing I was thinking from someone else - at least no fire alarms were pulled! Thanks.
Chief Honcho In Charge
Just to jump in and not hijack the thread...
Just to make myself feel better...I have a 4wd...can I just remove the covers, replace the gasket and fill it with new synthetic? I ask because the fluid has not been touched for two years (as the truck sat still) and who knows how long before then it was changed? I am noticing no adverse condition right now. Is it that straightforward...or am I missing something? Thanks, Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
There's really nothing else to it that I know of - I took off the old cover, caught the old fluid, let it drain all out - cleaned mating surface for the new gasket, I put on a little gasket sealer, bolted on the new cover, added fluid until it was at level of fill hole. Simple actually.
BE CAREFUL. If the truck sat for years, the inner axle seals may have dried out ( on some models) and the new synthetic could leak out. I would be darned sure there aren't any leaks for sure.
