10-04-2006, 09:44 AM | #1 |
Door lock question...
On my 70, the passenger door will not unlock via key. I am hoping this isn't normal. Can anyone tell me [1.] if it is the norm....[2.] If it's not can it be fixed w/o removing the lock cylinder?
Thanks!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
10-04-2006, 09:55 AM | #2 |
Re: Door lock question...
Will the lock turn with the key? (When the door is not closed?) If it will, it's a common problem, try pushing in on the door handle a little while turning the key.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-04-2006, 10:12 AM | #3 |
Chief Honcho In Charge
My driver side is a bit the same way. The lock know was frozen. I unfroze it. got it m,oving with some wd40. But...the lock fromt he outside will lock the door but not unlock the door.
I think I am going to have to take it apart and unjam it.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
10-04-2006, 10:14 AM | #4 |
No...the lock won't turn left at all...turns right like a dream though, guess I need to have it worked on.
10-04-2006, 10:18 AM | #5 |
take door panels off and spray the crap out of everything with wd-40 or pb blaster // window regulators and rollers too see if that helps
10-04-2006, 11:19 AM | #6 |
The Older Generation
If the previous suggestions don't cure it you could have a bent wafer inside the lock (usually caused from trying to force it to turn) or your key could be worn enough to cause the problem you are seeing. You can also have this problem if you have a big box store or hardware store make a duplicate key for you. Whenever I am making a copy of a key and it is worn excessively I mic the cuts, look it up in my book and cut the new key to factory specs.... Cures most problems.
If you pull the lock out and clean it up good there should be a code # stamped on the lock case or on the locking pawl. (the piece on the end of the lock that contacts the mechanisim inside the door) This is the code number and a new key can be cut from this number by any competent locksmith. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-04-2006 at 11:29 AM. |
10-04-2006, 11:51 AM | #7 |
IT'S A CHEAP FIX. YOU CAN GET A NEW IGNITION & 2 MATCHING DOOR LOCKS FOR AROUND $28. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
10-04-2006, 01:28 PM | #8 |
WD40 is the best. I soaked my door workings on Sunday with WD40. I did the door thing this morning and I can unlock and lock my driver door with the key from the outside...Sunday I could not unlock it...in fact the key would have broken off.
Fantastic suff.
10-04-2006, 01:31 PM | #9 |
What is pb blaster?
10-04-2006, 01:36 PM | #10 |
PB bLaster is a very good rust penatrant. I think I got my last can autozone a few years back. Dont really use the stuff anymore becuse I have undid every rusted bolt on my orange and white from Indianna. And most of the stuff out here comes loose with just plain old wd40. But I do recomend the PB blaster for all of you in the rust belt.
Aaron |
10-04-2006, 01:40 PM | #11 |
10-04-2006, 02:00 PM | #12 |
No problem.
Aaron |
10-04-2006, 05:09 PM | #13 |
i bought brand new matching door and ignition lock cylinders, and my passenger door lock will not lock from the outside, but locks just fine, and works fine from the inside.
