Old 10-22-2002, 12:58 AM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Question Better Heater fan/squirral cage? Rear heat for blazer/Subs
Is there a better more volume fan shroud for the heaters? I want to make a custom center counsle that routes heater/A/C ducts to blow on rear passangers. And need more volume. Any ideas?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 10-22-2002, 09:14 AM   #2
Chad
Chad's Avatar
Reumster
I had the same idea. Not yet to that point on the blazer though. My dad has a VintageAir unit on his 71 truck and it has more volume than my wifes 97 Ponitiac GTP. Only problem is it is LOUD!! This is on a non-A/C truck. I bought a center console from a 99 and up extended cab truck for my Blazer. It has A/C vents built into the back for the rear passangers. On a high hump, these consoles fit perfectly. Before I tore the Blazer down for the frame-off, I test fitted the console. It will be awhile before I get to the interior, as the blazer is in a million pieces in the garage.
Later,
Chad
Chad
69 Short Fleetside
72 2wd Blazer
70 4x4 Blazer
67 Chevy(big window) Just a cab for now
64 Chevelle SS (2dr Ht)
Chad is offline   Reply With Quote
Old 10-22-2002, 09:48 AM   #3
wild@work
What about one out of an 85 BMW 528e? It is mounted in the center console right behind and below the heater controls. German quality! Hey wait! I have one! I can get some pictures for you in a week or two ...
Wild
a.k.a. wild4wheels
'02 Subaru 2.5ts wagon
'67 Chevy C-10 Panel
Want to Buy:
-Used Car Trailer-Reasonable-in the Midwest
-67-72 1 Ton Dually-Reasonable-in the Midwest
-BURB QUARTER PANELS!
wild@work is offline   Reply With Quote
Old 10-22-2002, 09:51 AM   #4
Dan72cst
Dan72cst's Avatar
Just an idea, but my 93 suburban has an addition fan/squirrel cage in its rear unit. Maybe rigging up an addition fan would suit your needs.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 10-22-2002, 10:05 AM   #5
Reumster
L.E.D. Freak
Reumster's Avatar
All good ideas. But if I rigged another fan in the rear wouldn't I need another heater core? I really would like to keep all the big stuff under the dash and just route ducting.
(406)675-8082
