10-01-2006, 07:55 PM | #1 |
How to tell a c-20 from a c-30
Hello,
We just bought a 1980 chevy truck with a dump body from a salvage yard. According to the vin number it is a 1980 Chevrolet two wheel drive C-20 cab and chasis built in Baltimore. I am having a hard time getting brake parts for the truck. The parts coming off the truck do not match what is listed. The truck has dual rear wheels and eight lug wheels. Can anyone tell he how to tell the difference between a c-20 and c-30? Also, can anyone give me a clue how to find rotors, calipers, and flexible brake lines with out using the vehicle description? Thanks, Karl K and E Services |
10-01-2006, 08:29 PM | #2 | |
Sb 400 club
Re: How to tell a c-20 from a c-30
it might have c30 axles in it that some one swapped.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
10-01-2006, 09:40 PM | #3 |
Right turn Clyde
Im not sure if I have ever seen a 3/4 ton dually. I would bet its had a cab change if anything. I would look up one ton parts and see if that helps you get the right parts.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
10-02-2006, 11:28 PM | #4 |
Thanks for your help.
Charlie at the parst store somehow figured out that it has a P-20 axle. What is a P-20 ? |
10-05-2006, 10:00 PM | #5 |
p=step van series 20=3/4 ton 30=ton I would say someone swapped cabs and or rearends around.
10-05-2006, 10:44 PM | #6 |
7000 #'s of american IRON
I was about to say, check to see if it's a corp 14 bolt or Dana 70. Haven't heard of P-20. I'll also bet cab change.
look on the axle tubes- if you see little slag chunks on the tube in a location other than where the springs are mounted (+- about 4"), i bet the axle has been swapped too- the 3/4 and 1 ton frames are i believe 8 (confirm?) inches narrower to accomodate the extra tires with minimal flaring. Last edited by magnethead; 10-05-2006 at 10:46 PM. |
